Sanden 508 Air Compressors
The 1965 Buick Skylark I bought came with a A/C kit which was un-installed. Looks similar to Vintage Air but is not. Made somewhere in Texas. This Sanden style compressor has a V-belt drive. I tried to swap it out to the serpentine style to no avail.
In the meantime I bought a Kwik A/C relocation bracket because I am putting in an L92 motor out of a 2009 Escalade. The Kwik bracket calls for a Sanden 508 style compressor or SD5H14. This is getting out of my league and after tons of searching I am not sure what to buy. Prices run from around $140 to $220 if bought from Kwik. Looking for suggestions and of course trying to save money. Seams to be a lot of Sanden "style" compressors out there but I don't know the quality of them. Another reason for the post.
I have the compressor from the 2009 Escalade L92 motor. It is probably a variable speed unit. I don't think it will fit in the stock location of passenger side bottom. That is why I bought the Kwik relocation kit to relocate it to the top passenger side. I know it will fit there without problems. I don't know who cost effective it would be to pay shipping both ways plus the cost of changing out the parts. That is why I was looking into just buying a new one.
I personally would steer away from the stock compressors, I went through 2 before getting a sanden 508 at a car show from southernrods, which turned out to be a knockoff. The ac shop that charged my system for me said some of the knockoffs like mine are pretty good, hey it fooled me when I looked at it.That was about 4 years ago.
http://www.southernrods.com/categori...ressors-1.html
Street & performance carries a good line of parts & is knowledgeable, but not the most affordable.
PS, if you're who I'm thinkin of,check out my new air intake in my photobucket link & tell me what you think. Also look at my compreessor in stock f- body location- reboxed frame behind idler arm & small noch in crossmember which is less needed with sanden in place of factory comp.
Yes, the Southern Rods SD5/4514 is what I am looking for. $175 is not a bad price. Your new air intake is an interesting piece. It looks like 4 throttle blades up front. Racing only? I don't see where an air filter would go. I live in SoCal so I am not sure who you think I am.
Have a spectre air filter attached directly to maf . The (hat) sits over it & will have a plastic cover underneath. Both looks & function.
I believe we were trading notes on fast intake dimensions . You have the cool modified tuned port manifold?? I was designing my cross ram dual plenum ls1 intake which I still plan on getting back to one day.
My 52 Chevy came with a Sanden comp with a vee belt drive. I made up my own serp. belt setup (on a Gen 1 small block, now going LS), and found a compressor in the boneyard with a serp. pulley and switched just the pulley over. Found it in a Jeep Cherokee (or Grand Cherokee, was a few years ago). I think they're pretty common. I didn't want to get rid of a brand new compressor.
HTH, Jim
HTH, Jim
mount
"You have the cool modified tuned port manifold??"
Yes, that is me. I have made 3 of them now.
My local mechanic ordered in a bunch of different compressors with serpentine pulleys and tried to swap them with no luck. I will look into it a little further.
