Initial start (LQ4) bad noises! video
Old Sep 4, 2012 | 11:20 PM
wazzubob's Avatar
Default Initial start (LQ4) bad noises! video
This is an '04 Express Van LQ4 with ~160k. I heard the engine start and run in the yard before the engine was pulled. The harness and PCM have been worked by a couple experienced guys on another forum.
http://youtu.be/wiv4tt5IyOU
This is the 4thish start attempt. They all sound the same. The very first start a lot of fuel got dumped into the engine, enough to send raw fuel out of the tailpipe.
What do you guys think?
~Bob
Old Sep 4, 2012 | 11:35 PM
97camaroguy's Avatar
vats? just a thought!
Old Sep 4, 2012 | 11:42 PM
wazzubob's Avatar
Could vats cause that sound???? VATS should have been disabled when the PCM was tuned.
Old Sep 4, 2012 | 11:51 PM
ok so we can rule VATS out! I'm here for you dude let's figure this one out!
From the video it sounds like top end to me
But while we're at it,
we have confirmed fuel due to the "raw fuel" dripping its swag out the tips lol
have you confirmed spark?
Have you checked that the starter is disengaging? also kind of sounds like it's tacking against the flywheel ....
SO MANY POSSIBILITIES!
but yeah check spark
Old Sep 5, 2012 | 12:04 AM
wazzubob's Avatar
what method would you suggest to check spark?
Old Sep 5, 2012 | 12:49 AM
lol but honestly be careful. Get a second opinion before trying this
again, I am not recommending this. I don't find it safe.
Old Sep 5, 2012 | 12:56 AM
somebody else chime in here I don't want to kill this man!
Old Sep 5, 2012 | 02:32 AM
ls1nova71's Avatar
Is it running? Might be my phone speaker, but the first video sounds like 8 rods fighting over a quart of oil. Does it have oil pressure? If you dumped that much fuel in the engine, you NEED to change the oil! You've diluted your oil down with fuel and will toast the engine running it like that.
Old Sep 5, 2012 | 08:56 AM
wazzubob's Avatar
It will not stay running. It had 6 new quarts. Good point on changing the oil now it's been contaminated. I don't have an oil pressure gauge, but the sensor is plugged into the harness and my scangauge isn't showing any codes.
Old Sep 5, 2012 | 09:25 AM
Old Geezer's Avatar
What else have you done to the engine???
Camaroguy... Maybe take a step back and ???
Old Sep 5, 2012 | 10:57 AM
wazzubob's Avatar
Haven't messed with the engine much. I put on ls3 exhaust manifolds, had the original injectors tested and cleaned, but that's about it.
Old Sep 5, 2012 | 11:45 AM
@oldgeezer will do lol
I'm outtie 5000
good luck!
Old Sep 5, 2012 | 11:55 AM
Rick Speed's Avatar
Either bent a rod due to hydro locking it or maybe loose flywheel bolts.
Old Sep 5, 2012 | 12:15 PM
wazzubob's Avatar
What kind of noises would a bent rod make when just turning the engine over with the starter?
Old Sep 5, 2012 | 12:23 PM
wazzubob's Avatar
Are you thinking con rod or push rod?
Old Sep 5, 2012 | 01:32 PM
BudRacing's Avatar
Pull a valve cover and inspect.
Old Sep 5, 2012 | 08:46 PM
Chrome_Rust's Avatar
the PCM does not get an oil pressure sender input. The signal goes directly to a gauge. get a gauge on it. DO NOT START IT AGAIN.
To me it sounds like the bottom end is pissed right the hell off.
Old Sep 5, 2012 | 09:01 PM
Rick Speed's Avatar
Well That sounds exactly like my Nephew's car after he hydrolocked his motor and actually broke #7 connecting rod. I suggest taking a compression check
Old Sep 5, 2012 | 09:59 PM
wazzubob's Avatar
Thanks for the input guys. Tomorrow evening I'll do a compression test, and try to take a look at converter/flywheel bolts. Will report back.
Old Sep 5, 2012 | 11:12 PM
89gmcs15's Avatar
Huge exhaust leak? (just tryin to think simple and easy haha) My loose torque converter bolts sounded like a intermittent rod knock. That sounds like its knockin every revolution... Check everything and get a oil pressure gauge and get a automotive stethoscope and check stuff to see where exactly the knocking is commin from. You could pull valve covers and make sure everything is still there ha. What ever it is it sure sounds pissed off.
