Looking for suggestions for mounting Mike Norris PCV catch can
This is one of the last items on my list before I fire up the motor. I need to mount the PCV catch can, but the can is pretty big. Looking for suggestions.
Also does it matter if I mount the can higher, or lower, than the ports on the valve cover and TB? Can it be mounted on the firewall, or radiator support, or is a shorter distance recommended?
With my catch can I have a couple of places in mind to mount it. By the way I have not done it yet but thinking about it. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
1. I am using the Kwik A/C relocation kit and was thinking of attaching it to the A/C compressor using the outer lugs.
2. Was to make up a bracket and mount it to the inner fender.
