LT1 Tranny and Converter with Spacer on LS1. Will it work?
Also look for the round electronics plug on the side and PWM cast in the front pump. If you don't have the round plug and you have a square four pin plug it's a 4L60 and can't be controlled by the Gen III PCM at all. If it has a round plug but doesn't say PWM, the Gen III PCM can't control the lockup function properly.
https://ls1tech.com/forums/12585250-post5.html
