Ford headers on LS1
Old 10-24-2012, 11:05 AM
omc8's Avatar
Default Ford headers on LS1
Has anyone converted Ford headers to LS. I have heard that 351 Cleveland headers have the same primary spacing as LS ports. If they are it may be a option to start with, as I am planing on making my own headers for my swap.
Old 10-24-2012, 01:20 PM
superdave84's Avatar
I am not sure, but I think it's the small block headers that line up. But, if you are going to build your own, you can buy flanges from Summit for like $60 I think, and you can just build them out from there
Old 10-24-2012, 03:48 PM
bdonn8484's Avatar
I like this idea much more lol. Would be alot easier to go this route.
Old 10-24-2012, 04:42 PM
omc8's Avatar
Yea there are alot of choices for flanges. If it is just a matter of rerouting a couple primary tubes this would be the easy way to go. Other wise I will start from scratch.
Old 10-24-2012, 07:07 PM
99MUSTANG5.3L's Avatar
It's the windsor engines that are the same port spacing. I used cheap ebay headers for my swap($75) and some 3/8" thick flanges.
Old 10-24-2012, 08:53 PM
1bad03snake's Avatar
302 turbo header
Ls flange
I'm going to heat up the tubes and open the ports up with a 1/2 to 1 1/2" swedge I found at work
Old 10-24-2012, 10:50 PM
LS1 pwrd NOVA's Avatar
So is it a302 and a Windsor header that are similar?
Old 10-24-2012, 11:07 PM
302 and windsor heads are the same except the head bolt size. you can drill 302 heads out to fit a 351 or use spacers to run 351 heads on a 302.
Old 10-24-2012, 11:41 PM
LS1_PNY's Avatar
Then why does everyone use the 351W headers and not the 302? As the 302 are a lot cheaper
Old 10-25-2012, 02:13 AM
A 351 has a taller deck height than a 302 (9.5 vs 8.2) so the headers hug the block a little more for clearance around the steering shaft. As far as the heads are concerned you can swap them back and forth without an issues. Since I'm using 302 turbo manifolds I can mount the ls flange at almost any angle since steering shaft clearance is not an issue.
Old 10-25-2012, 03:05 PM
boostnut's Avatar
I think you can also find 351 headers with 1-3/4" primaries, the 302 headers are usually 1-5/8".
Old 10-25-2012, 06:29 PM
omc8's Avatar
Originally Posted by 1bad03snake
302 turbo header
Ls flange
Thanks for clearing that up, first I heard it was small block Ford . Then someone said it was Cleveland. Do they make a Windsor turbo header?
Old 10-28-2012, 07:44 PM
Bowtiedford's Avatar
I used 351w BBK, cut the flange off and put LSX flanges. fits like a glove. Now this was 6 years ago.
Old 10-28-2012, 07:47 PM
poopman's Avatar
They are still on the car
Old 10-29-2012, 07:02 AM
20 minutes with a torch and a swedge
I let a buddy of mine finish them up. I'm going to bring them to work and have them tig welded tomorrow
Old 10-29-2012, 12:49 PM
omc8's Avatar
^^^ Looking good keep us posted.
Old 10-30-2012, 11:39 AM
got the passenger side manifold welded up today. The flange got slightly warped. I'm going by a machine shop after work to get it straightened. I think a belt sander will straighten things out
Old 10-31-2012, 11:53 AM
Old 10-31-2012, 01:14 PM
omc8's Avatar
Looking good nice welds , did you bolt the flange down to anything during the welds?
Old 10-31-2012, 04:32 PM
No I put the header in my back pack and walked in threw the gate. I got one of the plants welders to hook me up. I'm bringing the driver side in tomorrow I might see if he can clamp it to a piece of flat steel before welding
Quick Reply: Ford headers on LS1
