4,000 ppm vss for 5.3 th350 swap what's everyone useing??
sawzall wielding director
If you can reflash the PCM (HPT or EFILive7, etc) it does not have to be 4000 ppm. On one swap I used the ABS sensor for the rear end (it had a latemodel rear end swapped in so there was a sensor in it already). I just adjusted for the lower pulse per mile and it worked fine.
