LS 1 Heater pipes
Some have blocked the heater connections with no problems, but the thermostat uses the heater circulation to work properly. You would be better off with a loop instead of blocking off. Others have plugged the existing holes, and then tapped new holes on the bottom side of the water pump to hook up the heater. http://www.vetteweb.com/tech/vemp_02.../photo_13.html
Put on a aftermarket straight thermostat outlet with the separate LS style thermostat - not a small block thermostat.
Plugging it might not be the bess solution.. from what i have read, it needs to flow as a bypass during heat up.. but I guess there are pro and cons for doing this..
BC
http://www.ebay.com/sch/i.html?_nkw=...mostat+housing
