DIY Harness,need wiring instructions.
Just be sure it crimps the seal tight enough that it doesnt pull out when you try and insert it into the connector.
If you are using the Gt150 3.5mm connectors the seal crimp actually needs to be an oval instead of round. As you stated in your PM if you need something crimped just let me know. As long as its not a whole bunch and you provide the materials I will crimp them for free just take care of the return shipping.
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
all the pinks connect to 12v+ign
ground it properly, disable VATS, Supply fuel, it will run.
Not fancy by any means, but it will work.
Heres how I did my first one;
http://www.thirdgen.org/techboard/lt...ll-engine.html
Fortunately I'd seen your work and know how much goes into it. I couldn't be happier with my harness.
BTW, to the guy that hung anchors by a butt connector, whoopie, I have mil-spec 550 cord too, but would you trust a single strand to hold your engine? Maybe to prove a point that it can hold it, but not for very long.
Im not saying it the best way to go by ganging them together but it will work. I run a new relay and fuse per specs on mine according to the wiring diagram i get printed from Alldata at a friends shop or on one of the boards. Its all about how much time you want to invest, its not very difficult, just go one pin or one sensor at a time.
I am really trying to find out if all the pink wires on a running splice is too much for one fuse. I see some guys do a fuse for coils, injectors, alt, o2's, ECU, fans, trans, almost everything gets a fuse.
I see the swap harnesses have 4 fuses, & two relays.
I am where I havent wired in the fuse block & have a 4 fuse block.
I also have 4 40amp relays. a relay for Main/fuel pump/fan1/fan2..
I know a wire from fuel pump relay control, fan 1 relay control, fan 2 relay control, and the main is the power to all?
this is the pic I am going with but trying to add two relays & figure out what he broke up the three fuses to do?
40amp relay for main with 30amp fuse?
40amp relay for fuel pump off main feed
30amp fuse- Driver coils & injectors
30amp fuse- Pass coils & injectors
30amp fuse- O2 senors
40 amp relay for fan1 of main feed
40 amp relay for fan2 of main feed
sound okay? will i have reason to catch fire?
inj bank 1 15amp
inj bank 2 15amp
maf 15amp
cooling fan ( single fan ) 15amp
PCM/Ign 15amp
Fuel pump 20 amp
O2's 10 amp
Throttle control 15amp
Anything else is ganged in there somewhere I just cant recall right now i spun this up almost 2yrs back now and this is the notes i have.
For anyone out there looking for supplies to build your harness or do any kind of harness repair work etc. I would stay clear from Delcity.net
My first few orders from them were no problem, ordered and received package a week later or less. Just recently I placed a order for 100 connectors. Almost 2 months went by and no package. Called multiple times and every time they gave some BS date on when they would receive them and ship out. Besides that my other nit pick would be that their tracking service is terrible. They have a separate page where you enter your order number to track the order and it never works. I don't see why they cant just provide the UPS tracking# via email.
Went with Waytek and order was shipped out the same day I placed the order, and I placed the order pretty late in the day too.. +1 for Waytek I will be ordering from them again.
inj bank 1 & coils 15amp?
inj bank 2 & coils 15amp?
maf- I am not running
cooling fan ( single fan ) 15amp fuse-(I am running two on there own 40 amp relays)
PCM/Ign 15amp
Fuel pump- 20 amp fuse instead of 40 amp relay? i can get a smaller relay
O2's 10 amp
Throttle control- Cable drivin- no fuse needed?
Check alldata for load ratings if in doubt. The sticky here might have the info too Im not sure i havent looked in there for some time now
Thanks!
I started this thread to bundle the 411 together n stop hijacking. Plus I can post exactly what I am dealing with in my own thread. Thanks for the info
