turbo lm7 foxbody swap
#122
#123
its been awhile. and my bad luck strikes again. got the new motor together. ran great, only to find metal shavings again. seems like something is wrong with the journals on the cam and its eating the cam bearings up. got a few good pulls in though. Had the car on 10psi for awhile. Now im on 12 and im in the process of wiring up the boost controller.
![](http://i1226.photobucket.com/albums/ee406/gearhead541/IMG_20140824_153524_zpscqxbn5tg.jpg)
![](http://i1226.photobucket.com/albums/ee406/gearhead541/IMG_20140824_194443_zpsnqeiyskw.jpg)
exhaust gets dumped in front of the rear axle
![](http://i1226.photobucket.com/albums/ee406/gearhead541/IMG_20140828_093443_zpswt9jml1s.jpg)
![](http://i1226.photobucket.com/albums/ee406/gearhead541/IMG_20140828_154041_zpszr6rv3yf.jpg)
![](http://i1226.photobucket.com/albums/ee406/gearhead541/IMG_20140913_131433_zpsahaq1eux.jpg)
Boostedgt at kots 2014
#125
#126
I'm in the process of doing a 5.3 swap myself, and after reading your thread it kinda scares me lol. The car is in really good condition no rust or anything, but I'm just a little apprehensive about the whole process.
#127
#128
#129
Yes I did a lot of extra fan that isn't needed. And the wiring isn't that bad. It may look confusing at first but just get some wiring diagrams and dive in. Label all your wires
#130
That's what I thought as well. Everything seems a lot more difficult if you're not physical doing it. Did everything else pretty much just bolt up? Like the k member to the motor etc?
#131
Upr motor mounts needed the holes opened up a bit to get everything to line up properly. There a pain to install and take part IMO not the end of the world tho. And doesn't seem like the powdercoating isn't holding up very well. Haven't driven the car much. And already has some that on the Kmember
#132
What would you say was the hardest part about the swap?
#133
There is nothing hard about it really. The swap itself is just like putting a normal engine in. Since you can buy everything to swap it. Everything will just bolt together for the most part. If you wanna do it that way. You can even buy pnp harness so a swap can be as easy or as hard as you wana make it
#134
#136
havent posted in forever. car has been up and running all summer. the aluminum 5.3 is doing great car made 560whp on 13-14psi and low timing. its now on 16psi and 20 degrees timing. will be turning it up to 18psi once i get a chance. it went a best of 10.3 at 136 on the 14psi and a 1.5 60 foot. havent been to the track since i turned it up and dialed the tune in. messed with the 4 link and have the car leaving on 12psi off the transbrake on the street. but like i said havent been to the track yet. heres a bunch of pictures and videos
![Name: 20150305_220102_zpsy3ew0exi.jpg
Size: 222.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647138d1501483635-turbo-lm7-foxbody-swap-20150305_220102_zpsy3ew0exi.jpg)
![Name: 20150307_094944_zps8dnt74ke.jpg
Size: 954.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647139d1501483635-turbo-lm7-foxbody-swap-20150307_094944_zps8dnt74ke.jpg)
![Name: 20150307_104631_zpsl6m3cyr7.jpg
Size: 812.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647140d1501483635-turbo-lm7-foxbody-swap-20150307_104631_zpsl6m3cyr7.jpg)
![Name: 20150312_102537_zpsrpsoxxwg.jpg
Size: 549.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647141d1501483635-turbo-lm7-foxbody-swap-20150312_102537_zpsrpsoxxwg.jpg)
![Name: Message_1426374492290_zpsmf9a2akx.jpg
Size: 331.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647142d1501483635-turbo-lm7-foxbody-swap-message_1426374492290_zpsmf9a2akx.jpg)
![Name: 20150316_154920_zpsdiv9rqpr.jpg
Size: 1.06 MB](https://ls1tech.com/forums/attachments/conversions-swaps/647143d1501483635-turbo-lm7-foxbody-swap-20150316_154920_zpsdiv9rqpr.jpg)
![Name: 20150318_145148_zpsa75zr95d.jpg
Size: 361.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647144d1501483635-turbo-lm7-foxbody-swap-20150318_145148_zpsa75zr95d.jpg)
![Name: 20150328_133905_zpstmtrhax4.jpg
Size: 718.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647145d1501483635-turbo-lm7-foxbody-swap-20150328_133905_zpstmtrhax4.jpg)
![Name: 20150328_152749_zpsmhanu23s.jpg
Size: 309.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647146d1501483635-turbo-lm7-foxbody-swap-20150328_152749_zpsmhanu23s.jpg)
![Name: 20150328_155615_zpst2vyylr8.jpg
Size: 304.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647147d1501483635-turbo-lm7-foxbody-swap-20150328_155615_zpst2vyylr8.jpg)
![Name: 20150418_135014_zps7vn5gxfm.jpg
Size: 598.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647148d1501483635-turbo-lm7-foxbody-swap-20150418_135014_zps7vn5gxfm.jpg)
![Name: 20150426_114503_zpsodndoben.jpg
Size: 1.21 MB](https://ls1tech.com/forums/attachments/conversions-swaps/647149d1501483635-turbo-lm7-foxbody-swap-20150426_114503_zpsodndoben.jpg)
![Name: 20150426_173502_zps26ika9b0.jpg
Size: 735.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647150d1501483635-turbo-lm7-foxbody-swap-20150426_173502_zps26ika9b0.jpg)
![Name: 20150502_025911_zpsnvekibsu.jpg
Size: 283.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647151d1501483635-turbo-lm7-foxbody-swap-20150502_025911_zpsnvekibsu.jpg)
never a good sign
![Name: 20150505_220356_zpsni6arhl9.jpg
Size: 368.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647152d1501483635-turbo-lm7-foxbody-swap-20150505_220356_zpsni6arhl9.jpg)
oops had a problem with the wastegate. too much boost on pump gas. took it apart. threw another piston in it and put the car on e85
![Name: 20150507_164044_zps6zbbueqw.jpg
Size: 595.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647153d1501483635-turbo-lm7-foxbody-swap-20150507_164044_zps6zbbueqw.jpg)
switched to hoosier qtp's
![Name: 20150606_120924_zpsinh9r7ka.jpg
Size: 403.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647154d1501483635-turbo-lm7-foxbody-swap-20150606_120924_zpsinh9r7ka.jpg)
street car takeover indy 2015
![Name: 20150725_235951_zpsy6sltudy.jpg
Size: 250.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647155d1501483635-turbo-lm7-foxbody-swap-20150725_235951_zpsy6sltudy.jpg)
![Name: 20150826_002147_zps3ieb3s75.jpg
Size: 350.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647156d1501483635-turbo-lm7-foxbody-swap-20150826_002147_zps3ieb3s75.jpg)
blew the posi out. started doing 1 wheel peels. it was time for a spool
![Name: 20150829_133452_zpskpbguiww.jpg
Size: 288.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/647157d1501483635-turbo-lm7-foxbody-swap-20150829_133452_zpskpbguiww.jpg)
street test pass
![](http://i1226.photobucket.com/albums/ee406/gearhead541/Mobile%20Uploads/th_received_1016324881734372_zpsrjlm3jjd.mp4)
street car takeover dyno. 14psi low timing and hot!
![](http://i1226.photobucket.com/albums/ee406/gearhead541/Mobile%20Uploads/th_20150724_162452_zpsehuban9g.mp4)
local street car shootout
![](http://i1226.photobucket.com/albums/ee406/gearhead541/Mobile%20Uploads/th_20150710_191611_zpsrlrdtwdg.mp4)
thats it! car is doing good. hoping to get to the track soon. possible forged motor and twins over the winter. we will see
never a good sign
street test pass
