LS Swap in 78 Vette
Old Jan 10, 2013 | 05:55 PM
donnie_19's Avatar
Picked up a vintage air kit from Old Dog today. Hope to get then engine bay painted tomorrow. 70 degrees so can have the door open.
Old Jan 12, 2013 | 03:08 PM
donnie_19's Avatar
Scored on a LS6 intake manifold, batwing oil pan and water pump this week. Old A/C is removed and ready to install Vintage Air system. Need to find a dipstick and oil pickup. Engine bay paint is well underway.
Old Jan 13, 2013 | 11:58 AM
donnie_19's Avatar
Didn't get an alternator with my engine. Will any LS work or do I need a certain amp? Going to use the Holley bracket for my PS and Alt. on driver side.
Old Jan 14, 2013 | 08:18 AM
donnie_19's Avatar
Also need the mounting bracket for alt. like this holley part http://www.summitracing.com/parts/hly-20-135/overview/
Old Jan 16, 2013 | 09:44 PM
donnie_19's Avatar
Made some progress today. A Arms are back in. Vintage Air box is temporarily mounted and need to make a few adjustments. Tried to mount the jeep box and the u joint I purchased from Borgeson is to small. Have to send back and maybe go with rag joint.
Old Jan 17, 2013 | 07:40 AM
donnie_19's Avatar
Need to find a set of 2001-2004 Corvette exhaust manifolds. Not a lot of options for headers with this swap.
Old Jan 17, 2013 | 11:52 AM
onedayjake's Avatar
Pics man! We need pics!
Old Jan 17, 2013 | 04:57 PM
2nd Gen Fl 'bird's Avatar
How come the Jeep box? I've seen comments before on people using these but, what makes it a better option than the factory steering box that the vette came with? Not just on a Corvette. Juuuuust asking.
Old Jan 17, 2013 | 08:00 PM
donnie_19's Avatar
The jeep box eliminates the leaking cylinder and 2 hoses. Here is a good write up on the conversion. http://www.vettemod.com/forum/showth...highlight=jeep
Attached Thumbnails LS Swap in 78 Vette-78-corvette-power-steering-old-system.jpg   LS Swap in 78 Vette-jeep-sterring-box-assembly.jpg   LS Swap in 78 Vette-jeep-sterring-box-parts-.jpg
Old Jan 20, 2013 | 09:16 AM
donnie_19's Avatar
Made some progress yesterday. New wheel bearings in front end. Coil springs and spindles installed. U Joint ordered from Borgeson for the jeep box conversion. Got my LS6 intake manifold and oil pan this week. Ordered new cam and other rebuild parts for the LQ9.
Old Jan 20, 2013 | 09:43 AM
RicOtt's Avatar
You asked earlier about which alternator to use. If you are using the Holley bracket, you must use the pickup style alternator. It was a great idea by Holley to do this. Truck alternator are plentiful and relatively inexpensive. I used this bracket and setup on a 58 vette I am restomodding.
Old Jan 20, 2013 | 12:29 PM
  #32
garys 68's Avatar
Good find on the LS6 intake and pan.
Btw, on the pan, you can reuse the o ring style gasket, but the manual reccomends putting a light coat of rtv about 1" long at the 4 corners where the front/back covers meet the block.
I've got an ecopy of the LQ4/9 manual if you need it.
Old Jan 20, 2013 | 12:47 PM
  #33
SargeZ06's Avatar
Picking up my LQ4 block today to swap into my 71 Vette. Long road ahead.
@ garys 68: can I get an ecopy of that manual?
Thanks
Sarge
Old Jan 20, 2013 | 02:35 PM
  #34
garys 68's Avatar
Send me an IM with your email address. Kind of a big file, not sure if I can attach it here.
Thanks
Sarge
Old Jan 20, 2013 | 06:00 PM
  #35
sssuch's Avatar
Don't let anyone bullshit You , the Truck manifold will make as much or more power than a LS 6 . As long as Your Cam is 225* duration or less @.050. The smaller the Cam the bigger the difference in power . And the truck Intake will fit under the stock Hood for Your Car. I got one in My Car , 1970 with a 73 up-Hood. Also if You Don't want Hedders, LS6 exhaust Manifolds fit like they were made for the Car. Stan
Old Jan 20, 2013 | 06:11 PM
  #36
-Q-'s Avatar
-Q-
Thanks
Sarge
Are you in the Louisville area? I think I see you post on the Louisville driver's thread on CF sometimes...
Anyways, give me a shout if you need a hand sometime. I'm still fine-tuning my swap.
Old Jan 20, 2013 | 09:11 PM
  #37
Gen1's Avatar
Going to be awesome.
Old Jan 21, 2013 | 06:19 PM
  #38
donnie_19's Avatar
Lets see a picture under your hood. I needed to go to a cable TB anyway and got a good buy on the LS6 manifold and TB with the injectors and other components.
Ordered some more parts today. Ordered the LS swap kit from Bowtie. http://www.tvmadeez.com/ls1_cam/ and a new filter and gasket for the 2004R.
Will be working on the jeep steering this week and changing the body mounts in front. Another while I am there. Glad to be putting more parts on than taking off.
Old Jan 21, 2013 | 06:58 PM
  #39
donnie_19's Avatar
Do I need the normal 145 amp or the 200 amp? Looks like $25 difference. Also going to need an adapter plug as my old set up was 1 wire.
Old Jan 22, 2013 | 06:57 AM
  #40
Fkns10's Avatar
Show some pics of the whole car!
