LS Swap in 78 Vette
Alternator wiring, I have the truck alt but which wire to get the Alt guage to work?
I got a set of Z28 dual fans and the Holley ECU will control when they turn on. How many amps do they draw and what kind of protection is required? Fuseable link, fuses or circuit breaker?
To the left is the oil cooler by-pass, and the original LS sender (with tap still in). Both drilled and tapped for 1/8" NPT.
Water - The passenger head (close to firewall) has a plug that can be removed and use an adapter like this - Several people sell them. http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
Alt - I am using the factory ECM to run the LS alternator. Do a search on one wire hookup, I believe you hook a resistor in line.
I had the other head drill and tapped for the SBC temp sensor.
http://67-72chevytrucks.com/vboard/s....php?p=3385719
Transmission cooler lines are hooked up and routed. Mounted the A/C bracket and had a clearance issue with the elbows coming out the top. Don't think it would clear the hood so picked up and elbow and a tee fill valve and good to go.
Water pump 90's are real close to the A arm hopefully won't be a problem with alignment.
Attempted to mount the power steering and alt bracket and the pulley on the PS hits the A arm so need a smaller pulley. Did get the PS hoses made for the jeep box.
The Throttle Body hits the neck of the water pump so going to need a spacer for that. Maybe can mount the Manifold air temp in the spacer. Suggestions?
Check out this thread:
https://ls1tech.com/forums/conversio...ap-pics-3.html
