LS Swap in 78 Vette
Sarge
Another while I am there. Removed 6 of the 8 body mount bolts. Just have the last 2 in the rear and need to reconstruct the rear mounts. The metal mounts are rusted out and the fiberglass housing will need some work to be able to support the mount. Only had one bolt so far that required the cheater bar. PB blaster on the bolts for a couple of days and will tackle the rear.
Have the body jacked up a couple of inches and will get the fuel line and fuel pump mounted . Will post a few more pictures when I get to that area of the restro.
http://www.summitracing.com/parts/vpn-gsl392
You need ~58psi. The 255 used by Q would be a better idea.
I used a factory Delphi (in tank) pump in my 74.
Duh on my part. Turns the Holley 12-920 is the same part as the GSL 392. Contacted Holley and they recommended this pump for my set up.
Serviceable like factory and no leaking or modifying the tank. I can then have my spare tire in place which is actually the not designed in safety in case of rear collision.
Is this the correct routing of the Wix 33733? Is the Dorman 800-159 correct for input from tank?
Got the front end suspension and steering installed today. Jeep box is in place.
Waiting on cam and will put engine back together next week.
I even had problems when I was lower on the fuel level when I was running the carbed 350. LS fuel systems move a lot of fuel.
