LS Swap in 78 Vette
Have had a couple of good days in the shop. Got the radiator installed with fans, Holley Program configured. All the sensors are wired to the harness. Garys 68 helped me figure out the radiator hoses and how to wire the Alternator. The spacer is installed in the Throttle Body that linkage clears the water pump neck. Picking up the pulley for the Power Steering pump tomorrow with the bushing installed. The fuel injectors should be in Monday.
Still need to figure out the air filter. Have to work out a different bracket for the TV cable. Will get the exhaust pipes fitted up on Monday and hope to try and start Monday night.
Ended up with a couple of nicks in the cylinder wall which were honed out. Engine assembler donated a different set of heads 241 which were milled .015.
Piston, rod and bearing inspected and deemed usable. Brian Tooley .650 Dual Springs and 7400 pushrods installed. Engine reassembled by machine shop. If there is a good thing its the machine shop didn't charge me for the repair or reassembly and the engine builder donated a set of heads. I was out my time for pulling the engine and reinstalling.
Next addition will be electric head lights.
Next swap this winter will be a T56 6 speed.
Going to do the electric headlight conversion while hood is removed. http://stingrayv12.com/services.html
