Pros and Cons of a Sumped Gas Tank?
You have the same drainage issue even with a suck up and down as you call it. I have a standard tank pick up that comes out near the top then loops down to the pump level with the bottom of the tank. If I get a leak it will siphon the entire tank.
Even with the bottom sump you will need some type of transition/bulkhead penetration from the sump to a filter to the nylon line. Weld an AN bung or on there and run a short section of push loc rubber hose up to the filter and from the filter out to a nylon transition piece. That will give you something to clamp should you ever need to pull the tank.
The web is full of guys who cut entire tanks in half to build baffles or put fuel cell access plates in the top of stock tanks to allow installation of internal surge tanks. There is always a way to modify a stock tank.
Also if he sumps the tank right he can have the fuel lines come out the front of the sump. That should help limit their exposure. It is also possible to put in a bulkhead fitting in the top of tank then run a fill tube down into the new sump. That shouldn't require massive tank surgery, gets the fuel lines up out of the way and still allows the external pump to be mounted low.
then when you have to change something, you have a shutoff.
I'm installing a 1/4 turn valve as the first thing connected to the Sump outlet on my mustang project
And yes, you want a low loss prefilter if possible.
