Finally attempting 5.3 swap into 1964 Impala
After my car sitting pretty much for most of the past 6 months due to it suffering from a "carburetor on the intake manifold" I've finally gotten the car in the shop. I plan to save money by sticking to a drive-by-cable 5.3 and keeping my 700r4. Now that this is finally happening and my car might be reliable enough to take trips longer than 2 miles I'm curious to see what gas mileage I'll get. Since suburbans/silverados get 13 in the city and 17 on the highway and I weigh about 1000 pounds less (about the same aerodynamics) what gas mileage should I get in my Impala? I'm hoping for 20 mpg highway but anything is better than the 10/12 I got on average (except for a freak accident of 14, but that was mostly highway).
Not sure what kind of mileage you'll get. That 700r4 should help with highway mileage though for sure. I'm planning on swapping a Vortec 5.3 into my 64 also but I'm just sticking with the original powerglide and probably doing a turbo as well while i'm at it. Goodluck with it, and make sure to do a build thread when you start swapping.
from my experience (a ls1 5.0l in a 65 impala), plan on getting the original tune for the VATS and rear o2 sensors then when you have everything together get a street tune by a company that does lots of them.
I pulled my hair out with error codes to find out the different exhaust needed a street tune.
I would guess at least 20mpg on the highway, and it will be lighter and faster.
good luck.
good luck.
good luck.
good luck.
I send the exhaust out, I was afraid to weld to my nice coated headers. The weld looks like crap, of course.
I wanted quiet, didnt really care about speed or sound. I forget what was put on the car. Ill get under it to see if there is anything on the mufflers.
I know they were 2.5" mufflers though.
LS1Tech Sponsor
My 64 Biscayne had an LT1 with 4L60E and a flowmaster 2 inch exhaust. The engine was stock and we drove it from New Jersey to Charlotte for a Good Guys Show. Car got around 25 mpg on that trip. With that engine and a 3.31 open rear the car went consistent low 14s. Fun to drive. LS3 going in it soon, though.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Yes, it will run fine. As others have stated, you may want to consider a 4L60E, if finances permit, as you wont have to worry about hooking up the TV Cable and you can taylor shift points in the PCM.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
What rear end you have in the car now? 8.5 10 bolt?
I know it's neither of those though.
I don't know why more people don't do these swaps. Sure they're expensive but you get street able gas mileage, and (after doing calculations) my 1964 impala should be able to beat a 409 425 horsepower 1964 impala. It'll do this with twice the gas mileage and twice the reliability.
you can try to reason with car people all you want but they think it is a sacrilege to change anything. Look at the whole bias tire thing, eventually people come around and the hard heads still buy them.
cant wait to see a vid of it running.
no exhaust
no exhaust
Also from the Barrett-Jackson auction it seemed about every fifth car was a Mustang. It also seemed that a good percentage of those were Shelbys.
If I remove my flow master 40s and replace them with stock mufflers will it affect the tune or not enough to matter? I don't dig drone. I tried them for awhile but I feel like I'm flying a small aircraft.
if you chance the exhaust, drive it. See if you get any codes.
Then check mileage. It should tell you.
I would have it street tuned. It will make sure everything in OK. I call it a $500 insurance policy that will tell you HP. It will also let you lower the temp the fans come on (if you didnt lower it already).
