Steam line vent kit....
Old Feb 14, 2013 | 07:01 PM
Doug G's Avatar
Originally Posted by BOXCHEV
Couldn't you just get 4 of the factory block offs and tap it for 1/8" npt to -an 3 or 4 fitting then use 90degree -an elbows.
Is possible I guess....but I have 4 fittings and the hose is on backorder. Why sell a "kit" and not have half the parts ????
Old Feb 16, 2013 | 01:21 PM
LSGUNSS's Avatar
formerly 2000blackcamaross (6-25-2013)
Some of my buddys just drill and tap the factory stem tubes. Then run the lines/hoses where they want.
Old Feb 16, 2013 | 06:34 PM
Doug G's Avatar
WOW....parts were on step today. UPS guy must of been running late
BUT I got my "stuff" and here they say on backorder until 3/17/13 ?
Now to install Sunday ?
2~hoses (@ 16" ?)
12~spring clamps
4~90's
4~adapters
1~Tee
1~ X
Old Feb 16, 2013 | 08:15 PM
01cherryreds10's Avatar
I dunno the kit seems sorta cheap looking. I suppose if you dont care how it looks or your on a budget then this is a home run but for a little more money you could of done a KUP style setup
Post more pics when its installed maybe I'm wrong
Old Feb 16, 2013 | 08:21 PM
Doug G's Avatar
I will do the braided line when more $$$ comes back.... all these little things are eatting me up
Mostly hidden by intake anyway I guess.
Old Feb 17, 2013 | 01:37 PM
Doug G's Avatar
It's in....still have some wiring,hoses,belt,and a T-stat to do.
Old Feb 17, 2013 | 06:12 PM
87lsttop's Avatar
that looks good where are you going to hook the steam vents up to?
Old Feb 17, 2013 | 06:14 PM
Doug G's Avatar
Waterpump
 Michael S. Palmer
Old Feb 17, 2013 | 06:37 PM
sixtoes1313's Avatar
I like the modded factory lines, or brake line idear better! But it works. I think my rear ports are blocked off- no room between the blower and valley plate for a line to run
Old Feb 17, 2013 | 11:20 PM
Oh wow that doesn't look too bad at all. I didn't know that kit was made for the high rise intakes.
Old Feb 19, 2013 | 12:56 PM
87lsttop's Avatar
Are you drilling and tapping the front of the water pump or are you runninga t block into the side of the water where the inlet and outlet are for the heater lines?
Old Feb 19, 2013 | 03:07 PM
  #32
zapp109's Avatar
Where are these lines supposed to run to? Radiator? I seen hes running to water pump.
Old Feb 19, 2013 | 03:52 PM
  #33
Doug G's Avatar
Yes, to the waterpump near the T-stat...on the suction side.
Most of the swaps I've seen go there or to a fitting in the upper hose.
Beings the steam/vent lines are on the pressure side, it will be fine.
Old Feb 19, 2013 | 03:54 PM
  #34
zapp109's Avatar
Ok good to know.
Old Jul 31, 2013 | 05:50 PM
  #35
jalper's Avatar
Restricted User
I guess If I am going to spend that kind of coin I want it to look like it should be on a race car not a daily driving import,
I went with this kit
http://www.ebay.com/itm/LS1-Steam-Port-AN-4-Fittings-with-Bypass-Hose-Kit-In-Black-Finish-/221255138423?pt=Race_Car_Parts&hash=item3383d57c77&vxp=mtr#ht_318wt_1160
Attached Thumbnails Steam line vent kit....-steamport-motor.jpg   Steam line vent kit....-steam-port.jpg
Old Jul 31, 2013 | 07:54 PM
  #36
snook's Avatar
Got my stocker for 20 bucks at local junkyard
Old Aug 1, 2013 | 01:56 AM
  #37
Busa_rob's Avatar
What do these do anyways? I seen this in the box of parts I got with my lq4.
Old Aug 1, 2013 | 04:18 AM
  #38
dmracing's Avatar
Vents steam vapor out of the head to eliminate hot spots.
Old Aug 1, 2013 | 06:11 AM
  #39
zapp109's Avatar
What motor is that from?
Old Aug 1, 2013 | 08:10 AM
  #40
snook's Avatar
The steam line was off a truck motor at the junkyard, not sure what year it was.
