93 Notchback 370/GT91 Street Car
Here is the start of my build, It's a 1993 Mustang Notchback getting a turbocharged 370. It will be mainly a street car with the occasional track visit.
Engine
- 370 CI Lq4 Iron Block
- Wiseco -11cc Pistons
- Eagle H-Beam Rods (6.125"
- Clevite H Rod & Main Bearings
- Stock Crank
- ARP 2000 Rod Bolts
- ARP Main Studs
- ARP Head Studs
- PRC 260cc Aftermarket LS3 Heads
- Holley 102mm EFI Hi-Ram Intake Manifold
- FIC2000 Fuel Injectors
Turbo
- GT91 T4 Turbocharger
- Flipped Truck Manifolds
- Stainless 2.5 Tubing
- 4" Downpipe
- 4" Core Intercooler
- 4" Cold Side
- Precision Turbo 46mm Wastegate
- E-Boost 2 controller
Trans
- TH400 RMVB & Brake Built By Me
- FTI 3600 Stall Converter
- Meziere Billet Flexplate
- B&M Ratchet Shifter
- B&M Cooler
Rear
- Ford 8.8
- Traction Lok Differential
- 3.55 Gears
- Moser Axles
When I started
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch2_zpscf48d392.jpg)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch3_zpsefae4fcb.jpg)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch4_zps7cfca907.jpg)
3 hours later
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch6_zpsa3fb237b.jpg)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch7_zpsaf04b892.jpg)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch8_zps48637be2.jpg)
New K-Member & Steering Shaft
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch9_zps9f82f35d.jpg)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch10_zpsae4fc390.jpg)
Engine
- Stock Crank
- ARP Main Studs
- ARP Head Studs
Turbo
- 4" Downpipe
- 4" Cold Side
Trans
- B&M Cooler
Rear
- Ford 8.8
- 3.55 Gears
- Moser Axles
When I started
3 hours later
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/TurboNotch12_zps9cdccbe7.jpg)
Motor is in the works should be done next week
I'm waiting for my pistons to arrive so I can balance my internals
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/85D424C4-ED48-4907-A89D-A00455EEA991-1863-0000002E770EC495.jpg)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/2F9F11C6-4689-40CB-A37E-1309F1A61236-1863-0000002E7A6D3C51.jpg)
Update
Block has been align honed with the studs and main/rod bearing clearance set. Still waiting on my pistons for balancing![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/D8252D06-3FE8-4786-8FE1-70CE57682673-13998-00000176A515395F_zpscb040153.jpg)
![](http://i134.photobucket.com/albums/q114/Xpeditious/Turbo%20Notch/27EBD79F-E434-40A1-B27D-62EAD8148E09-13998-0000017699B479CA_zps2de8b43a.jpg)
