Oil pan?
CTS-V is can be used, but still will (most of the time) hange about 1" below the x-member. Will also need to move the engine back as far as you can get it (and up).
I bottomed out on mine and cracked it. 20 mile ride home in a Tow truck.. !
F-Body can fit, but is way to tight IMO, would not recommend it without notching it.
Holley and MAST are good recommendation for a Cast Pan, as is most of the steel pans.
these are just my opinons..
BC
I spaced the frame mounts up, because I was originally using a modified truck pan which has the lower front area that interferes with the steering linkage. I am very happy with the modified F-body oil pan. The pan that you see behind the crossmember is the transmission oil pan, which would never touch anything unless you plan on going offroading.
Second Pic: Trans replaced with T56 (can barely be seen in lower left), the engine still in the original location.
This is in a 2nd Gen F-body. Research fitment first. Your luck might not be as good as mine, but you can get a batwing all day long on ebay for less than $150.
