Loose Dipstick Issue
Problem is that removing the dipstick so many times the press fit into the block has become loose and I am concerned of leakage. I am open to any recommendations. Perhaps trying the flair the press fit area of the tube. Maybe a sealent or some sort. I would like to avoid any permenant options like tack-welding or JB weld, but may entertain them if nothing else works. Thanks for any help!
I was able to cut down the original tube support leg for the job. With the new support leg in place the tube is pretty solid. But I would rather be safe then sorry. There is almost nothing I hate more then cleaning up oil leaks!
And thank you for the compliment. If you are cutting down the stock tube I would recommend a couple practice welds on the scrap to get the hang of it. And keep your welds near the end of the tube so you can get a cartridge roll or rat tail file down the tube to clean up any penetration. I had too.
Another nifty trick, I made a small tight fitting wad of brake clean soaked paper towel and forced it through under air pressure. There was a lot of grudgy oil and metal flakes in the tube!
Best of luck to you both!
BC
