FUEL LINES: Nylon vs. Stainless braided vs. Hardlline
Man, I'm a jerk for not posting it aren't I? Sorry.
I'll gather a few photos and make a topic on it then update this thread with a link. Budget nylon fuel line tool.
I never found one, but I stopped looking years ago. In my research it seemed to get from style A to style B you needed at least two fittings if not three. From -xyz (AN) to GM EFI quick disconnect required a quick disconnect adapter, a -xyz adapter and a -xyz termination for the hose and finally the hose. This gets expensive (beside the price of the hose in the first place) and takes a ton of unnecessary room.
Last edited by gofastwclass; 03-04-2013 at 07:26 PM. Reason: Added link to topic...
If you go junk yarding look for some LT1 cars. The Caprices and Buick Roadmasters ran nylon links that hook up directly with little or no work. The beauty of nylon lines is you can route them easily any way you like just make sure you have a good way to hold them otherwise they can hang. I picked up multiple lines for about $10 and even got extras. If you need to swap the ends you can use the dorman repair kit to splice 2 different ends. I went back to hard lines under the car but that was only because I had them from the donor car. The transitions are still nylon.
Looks like I am going to be running Nylon. Purely for cost. I am going to do what was shown above, and just use a home made tool to press the fittings in. Should be around 50 bucks for lines. That will help out my budget. I looked into the Nickel Copper lines too, as they look to be a better alternative to stainless.
