BMW e34 Touring LS1 swap (BMW 5 series wagon)
Old 05-20-2013, 08:28 PM
  #101
ctd450's Avatar
what are your welder settings? gas or flux?
Old 05-20-2013, 08:40 PM
  #102
vazfx16's Avatar
Setting depends on what I am welding. Gas.
What have been doing on the tubes is to get a heat a bit hotter and slow down the wire speed to allow me to move a bit slower for better control of my hand movement.
Do folks have best practices for how to keep the flange from warping whiled welding.
Old 05-25-2013, 08:36 PM
  #103
vazfx16's Avatar
Collector work.
Passenger side header.
Velocity cone got ground smooth for flow.
Old 05-31-2013, 09:00 AM
  #104
LQ4-E39's Avatar
Bolt it to a junk head using all the bolt holes available on the flange to prevent warping.
Old 05-31-2013, 10:36 AM
  #105
ctd450's Avatar
tack the flange to a length of box or rectangle tube, or that stand in your second picture if it's flat and not bent. One tack at each end, and a few between. Let it cool fully before cutting the tacks off.
Old 05-31-2013, 07:59 PM
  #106
vazfx16's Avatar
Thanks for the advice on the warp avoidance
Both great ideas. I wish I had a junk head, but don't.
I was considering tacking it down and stitch welding around the tubes and letting each stitch cool before continuing
Old 06-02-2013, 11:37 PM
  #107
SpeedyMerrickan's Avatar
what a cool swap. there will be many unsuspecting passerbys
Old 06-04-2013, 11:08 PM
  #108
vazfx16's Avatar
Thanks. Looking forward to surprising some folks
Old 06-23-2013, 12:31 AM
  #109
vazfx16's Avatar
I am going to sell my Dinan Chip and and DME.
Got my driveshaft now
Old 07-07-2013, 03:20 PM
  #110
vazfx16's Avatar
Old 07-07-2013, 03:59 PM
  #111
red04montels's Avatar
glad I checked back in on this one, looks like it's going well! keep up the good work!
Old 07-07-2013, 04:30 PM
  #112
vazfx16's Avatar
Thanks red04, I am actually very close to being done. The last details of ac lines, fuel lines and ps lines is where I am. Just a matter of spending money now. All the harder things are done.
Once I try to start, I am sure there will be things to solve, but...getting close.
Old 07-14-2013, 11:45 AM
  #113
vazfx16's Avatar
Filter/regulator and fittings
Created a little mount for filter and regulator where the stock BMW dual fuel filters used to live.
Get the tran's/engine's marriage back together single-handedly was fun to say the least.
Old 07-15-2013, 12:14 PM
  #114
LQ4-E39's Avatar
doing it alone with both a crane AND a trans jack looks like cake! i slammed mine together using only a crane holding the motor, and the trans resting on a pallet...THAT sucked.
How did your center support bearing replacement go? Mine is torn too, I have to replace it this week before I leave for waterfest.
Old 07-15-2013, 12:18 PM
  #115
vazfx16's Avatar
Changing with crane and jack made it easier. I just could not get the trans to get all the way easily. The dowels had a bit of corrosion, so I had to clean them, then the alignment was not spot on so I had to grab and wrestle the trans into position.
I have not done the CSB yet, waiting for the part to come in. I have a feeling it won't be fun. I plan on welding on a long bar to a box wrench to multiply the torque. Have you done your's yet?
What and how did you do with all the emissions hoses? How did you close them off?
Old 07-15-2013, 01:06 PM
  #116
LQ4-E39's Avatar
I haven't done mine yet, I was wondering if you had done yours and had any tips. I'm going to give it a shot tonight when I get home if I can find the part. Bought it months ago and never installed it.
IIRC there were two small emissions hoses going from the fuel tank to the engine bay. One was a small hard plastic hose that slipped over a nipple molded into the plastic intake elbow, and the other was a rubber line that was probably for a breather line. I think both lines are just hanging there uncapped. I wasn't sure if they were breathers for the tank, so I didn't want to cap them. You may want to ask some of the other BMW swappers.
Old 07-15-2013, 01:30 PM
  #117
vazfx16's Avatar
Originally Posted by LQ4-E39
...IIRC there were two small emissions hoses going from the fuel tank to the engine bay. One was a small hard plastic hose that slipped over a nipple molded into the plastic intake elbow, and the other was a rubber line that was probably for a breather line. I think both lines are just hanging there uncapped. I wasn't sure if they were breathers for the tank, so I didn't want to cap them. You may want to ask some of the other BMW swappers.
Cool
will do
Old 07-15-2013, 05:50 PM
  #118
kesslerbmw's Avatar
Keep the updates coming.... I don't post every time you update, but its makes my morning when I wake up and see an email from this thread. Keep up the good work.
Old 07-16-2013, 12:37 PM
  #119
vazfx16's Avatar
Thanks Kesslerbmw,
My progress seems so incremental now. it is like 1000 tiny little things to complete. Last night I completed the filter/regulator setup. Tonight, I am going to try and get my center support bearing off. I am anticipating lots of sweat.
I am also waiting for parts to come in...like hose splice adapters from JTR.
I do have an idea for my Powersteering that will save me some bucks. I am going to graft a stock LS1 pressure hose to my BMW pressure pipe (with banjo fittings). I will put a sleeve over the two pipes and weld it up. Should work well. Then I will use the stock return BMW Power steering hose, and run it through the stock power steering cooler
Old 07-16-2013, 10:39 PM
  #120
vazfx16's Avatar
Default Easy way to remove BMW Center Support Bearing
Folks,
I thought this might be helpful since it made short work of removing my center support bearing.
Tools:
  • Monkey wrench -- keeps the u-joint from turning
  • Box wrench
  • Piece of pipe or tubing the will fit nicely over the box wrench end
  • Piece of flat bar steel -- to help hold the box wrench onto the bolt
  • 2 x 4's to help keep the monkey wrench perpendicular to the ground
Set things up like this
I was able to remove the bolt in about 2 minutes.
POW!
I'm not sure if I will reuse the bearing or not, so I will wait until I get the new CSB to decide if I will pull the actual bearing or not.
Quick Reply: BMW e34 Touring LS1 swap (BMW 5 series wagon)
