ls1 conversion for 66 impala info req,d
Old Mar 3, 2013 | 12:37 AM
chisel57's Avatar
Smile ls1 conversion for 66 impala info req,d
Greetings, help required.Do any of the enthusiasts out there know of a step by step guide to installing a ls1 engine(keeping the injection system preferred) and its factory auto transmission into a 66 impala coupe lhd ? need to know the specifics to determine whether it is a viable transplant.im sure that someone would have attempted this. all leads appreciated.
regards chisel 57
Old Mar 3, 2013 | 12:03 PM
psiconversion's Avatar
LS1Tech Sponsor
You will find tons of information on the forum. The 66 is going to be similar to an A-body as it is not an x-frame like the earlier Impalas. If you do a search you will a lot of things to help with figuring out the mounts, fuel system and wiring. If you have specific questions. Just ask.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 3, 2013 | 06:09 PM
kwhizz's Avatar
Here you go...........everything you need is in this thread....
https://ls1tech.com/forums/conversio...onversion.html
By Brett Foote | 2026-06-04 05:00:17
