Relocating throttle body?
-Don
-Don
Just make sure to keep the mass airflow sensor up wind of the TB.
The only reason why I am doing this is due to clearance. If I attach the TB to the intake manifold, I am going to have an extremely tight bend coming off of it to clear, which just seems like I would be losing out on quite a bit of power. I probably have 2 of room at most to work with, if the tb were attached directly to the intake manifold.
-Don
thanks.
-Don
Those would work well, if something like that came in 102mm form.
-Don
You could prob weld onto a ls1 throttle body adapter if you dont feel like making a flange.
https://www.google.com/search?q=ls1+...iw=768&bih=928
I contemplated doing just this on my '90 300zx swap for the same reasons. I was worried if it would function correctly or not; but this thread affirmed what I had thought.
Also, wouldn't the extra volume of the 'elbow' effectively increase the plenum volume, thereby possibly improving performance (or not!) ?
I understand that one of the claims to fame of the LS6 manifold is increased plenum volume, among other things. I would think that any increase in volume after the TB could be considered an increase to the plenum volume - and maybe it makes no diff at all
but I agree - with FI it's very likely not gonna be noticed.
