Clutch Fork PROBLEM NEED HELP
Old Mar 31, 2013 | 06:43 PM
Mr5.3cammedup's Avatar
Default Clutch Fork PROBLEM NEED HELP
Got a 79 malibu that had v6 swapping to a 5.3 with valve spring cam job
Bought the 621 bbc bell housing , nfw1050 flywheel , performance clutch kit
MY PROBLEM
The throwout bearing arm or clutch fork from the v6 wont line up in the 621 bbc bell housing
So which clutch fork arm i need CAN SOMEONE HELP ME PLEASE
Old Apr 1, 2013 | 11:21 AM
can someone tell me something
Old Apr 1, 2013 | 04:04 PM
Project GatTagO's Avatar
First of all, how are you going to attach the z-bar to the engine?
Is this the fork that you have now?
Post some pictures. What exactly is "not lining up?"
Andrew
Old Apr 1, 2013 | 08:39 PM
Unhappy
its not lining up in the center of the pressure plate nor will it sit on the ball
tryin to see if theres a different fork arm cuss the one i have comes off a v6
Attached Thumbnails Clutch Fork PROBLEM NEED HELP-2013-04-01-20.32.21.jpg   Clutch Fork PROBLEM NEED HELP-2013-04-01-20.33.06.jpg   Clutch Fork PROBLEM NEED HELP-2013-04-01-20.33.14.jpg
Old Apr 1, 2013 | 10:10 PM
CattleAc's Avatar
3892632
Pretty sure this is the part number you need for your application.
Do a search with this #.
Old Apr 1, 2013 | 10:16 PM
thank u will do
do u know of a site that carry this fork???
Old Apr 1, 2013 | 10:34 PM
CattleAc's Avatar
thank u will do
That picture I "borrowed" from Pace Performance I think...if I remember correctly they wanted like over $40 bucks...
I think Summit/Jegs has them for under $20...
Google that part # I gave you, there will be lots of places that handle it.
If you search a little, I'll bet there are vendors on this site that will have what you need.
It's nice to support them.
Old Apr 1, 2013 | 10:47 PM
Im looking right now thanks a bunch
Old Apr 1, 2013 | 10:55 PM
garys 68's Avatar
Tamraz, opgi, the parts place, year one, ebay...
you need the bbc 168 tooth version for the 621 bellhousing, not the sbc 153 tooth version.
thank u will do
Old Apr 2, 2013 | 06:21 PM
Thanks Gary68 and CattleAc for helping me out ordered the clutch fork from the parts place today BUT they dont have that throwout bearing with the 1.25 diameter and part store here in my area dont have it either
Do yall have a part # for the throwout bearing?
Old Apr 2, 2013 | 11:03 PM
garys 68's Avatar
1.25" is the depth of the throwout bearing. Trust me, they have dozens of them in every parts store in the US. It's the most common one used on GM vehicles.
Just have them look up one for a 70 BBC chevelle, same as the fork, about $12.
Old Apr 2, 2013 | 11:23 PM
**** i asked them to pull up one that compatible to the 1050 flywheel 84.99 what they told me
that was o reillys
then one had like a 1.248 but will double check tomorrow
Old Apr 2, 2013 | 11:39 PM
garys 68's Avatar
That sachs flywheel is used in 1999+ trucks. They use a hydraulic throwout bearing. You need one that works with the 621 bell, fork, and z bar.
I just looked up a 70 chevelle, 454 release bearing on Rock Auto, $13.
Read this carefully:
http://www.novak-adapt.com/knowledge/clutches_etc.htm
Old Apr 3, 2013 | 12:51 AM
Roger that
