lsx mustang/reverse lights
Old Apr 4, 2013 | 11:54 AM
cordova87's Avatar
Default lsx mustang/reverse lights
ok fellas need help here!! how do I wire the reverse light in the mustang to the ratchet shifter?
Old Apr 4, 2013 | 01:47 PM
bjamick's Avatar
You could use a simple micro switch if you wanted.
Old Apr 4, 2013 | 04:37 PM
MustangLS's Avatar
That reminds me I never did hook mine up. My ratchet shifter came with a couple of micro switches I know one was intended for the reverse lights.
Old Apr 5, 2013 | 12:56 AM
stangtrader's Avatar
Next question should be what wires in the stock mustang harness do you tap in to? I havent looked in alldata yet but so far my experiance has been that alldats diagrams for fox wiring is poor
Old Apr 5, 2013 | 07:27 AM
club_xcursion's Avatar
easier to chase it from the taillights forward. i had to do the same to mine when i put a c4 in my car.
Old Apr 5, 2013 | 08:47 AM
RATBOX's Avatar
There's a wire connection down at the trans tunnel that plugs into the Ford T5 or AOD for reverse lights. Look in the trans tunnel vicinity.
This is the one for the T5:
The T5 is a two wire connection and as I recall the AOD harness is a 4 wire. In either case you should be able to make a micro-switch complete the circuit through some minor trial and error.
Old Apr 5, 2013 | 09:32 AM
chiaj144's Avatar
Your looking for a 4 wire harness under your console. While your hooking up your backup lights use the other two in the harness and hook up your neutral safety switch if you haven't already. Depending on the shifter yours may already be setup for them.
Old Apr 5, 2013 | 10:06 AM
v8sten's Avatar
I wired mine to my hurst shifter, mine was an auto and it had 4 wires like stated above. 2 for the neutral safety switch ans 2 for the reverse lights. they are on the drivers side of the trans tunnel.
Old Apr 6, 2013 | 01:38 AM
bjamick's Avatar
Old Apr 7, 2013 | 10:24 PM
cordova87's Avatar
thxs fells for all the info have been busy but ill look at it right now, i do recall it that it had that t5 harness not sure if its a 4 wire or 2 ill post pics
Old Apr 8, 2013 | 12:28 AM
cordova87's Avatar
how did you wire it? here's the harnesses
Attached Thumbnails lsx mustang/reverse lights-reverse-lights.jpg
Old Apr 8, 2013 | 12:30 AM
cordova87's Avatar
cool thxs so do i just connect those wire to the micro swtich? or is there a way they go?
Old Apr 8, 2013 | 10:05 AM
v8sten's Avatar
I cut the connector off and pulled it inside the car and stripped the ends of the wire off and figured out which wires let me start the car and which turned the reverse lights on. 2 are ground wires and the other 2 are, 1 for reverse lights and 1 for neutral safety switch.
Old Apr 8, 2013 | 03:07 PM
cordova87's Avatar
do you know whats the other harness for? on the pic besides the transmission reverse lights one, as fas as the reverse safety switch do i need 2 or just one? idk how to go by connecting those 2 wires into the reverse safety swicth one an one to the safety switch?
Old Apr 8, 2013 | 04:24 PM
v8sten's Avatar
what year is your car
Old Apr 9, 2013 | 07:12 AM
Sarg's Avatar
Subscribed for the near future. Good info here. Wondering if this is my my starter wire will not go hot.
Old Apr 9, 2013 | 10:57 AM
v8sten's Avatar
correct. neutral safety switch
Old Apr 9, 2013 | 11:33 AM
Sarg's Avatar
I figured with a manual body car it would just be the clutch switch?
Old Apr 10, 2013 | 02:32 PM
cordova87's Avatar
92 coupe was 4cyn manual t5
lsx swap lq9/4l60e just trying to get these reverse lights on
Old Apr 10, 2013 | 05:26 PM
v8sten's Avatar
I would think the same too. I can only speak from my personal experience though. i have a 86 v6/auto car. Lemme ask a few friends.
