My 1963 Ford Econoline 4.8/6L80E build
Old Feb 5, 2014 | 10:58 PM
  #41
1liftedz's Avatar
Originally Posted by trozfan
Man that tucks NICELY, keep up the good work. This is one bad *** van!
Old Apr 19, 2014 | 07:14 PM
  #42
trozfan's Avatar
Some latest fab work:
Cut out the rear corner and wheel well opening. Corner was damaged and rusted. I am widening the wheel opening by 3 inches.
Cutting everything out.
New panels clamped in place. Notice the widened opening with a piece I cut from the old panel
Now on to the new flush gas door I will be adding. Need to fab a recess for the door that I will weld into the side.
More gas door fab
1963 Econoline repair panel
1963 Econoline Audi TT flip gas cap
Old Apr 20, 2014 | 11:22 AM
  #43
Ls1.63cad's Avatar
Now this is a build to follow great job
Old May 30, 2014 | 05:25 PM
  #44
trozfan's Avatar
Finished the welding and did some body work/block sanding of the rear corner.
Now for a custom wheel tub
1962 Econoline custom wheel tub<br/>1961 1964 1965 1966 1967
Old May 30, 2014 | 09:53 PM
  #45
LilJayV10's Avatar
This is awesome.
Old May 30, 2014 | 10:12 PM
  #46
ACHTUNG's Avatar
Epic.
Old Jun 2, 2014 | 10:25 AM
  #47
Accrdwgnguy's Avatar
Amazing, nice work.
Old Jun 2, 2014 | 10:45 AM
  #48
droopyzda1's Avatar
Beautiful craftsmanship. Great build. Just curious, would a late model ford crown vic front suspension set up work for that van? I have seen it done to the ford f100 trucks of that era but I wonder if it will work for you? Just a suggestion.
Old Jun 2, 2014 | 02:01 PM
  #49
DEEDDUDE's Avatar
Thanks for the update, glad to see you making progress.
Old Jun 4, 2014 | 08:23 PM
  #50
trozfan's Avatar
I've looked into that, I think the hub to hub measurement is about 5" too wide. Would've been a nice option
Old Jun 4, 2014 | 08:30 PM
  #51
trozfan's Avatar
I did check out the Aerostar front suspension, as they are a one piece bolt on as well, with a narrower hub to hub than the Crown Vics. It is an odd hideous looking set up though
Old Jun 5, 2014 | 09:47 AM
  #52
Hart_Rod's Avatar
Sweet build!
Old Oct 19, 2014 | 07:21 PM
  #53
Ls1.63cad's Avatar
Any updates
Old Oct 20, 2014 | 11:54 AM
  #54
DW SD's Avatar
Love what you are doing! Hope some progress has been made.
Doug
Old Nov 3, 2014 | 08:38 PM
  #55
trozfan's Avatar
Finally got my rendering done. Had my good friend and automotive CARtoonist George Trosley do it for me.
Old Nov 3, 2014 | 08:42 PM
  #56
trozfan's Avatar
Old Nov 3, 2014 | 08:46 PM
  #57
trozfan's Avatar
Lots of progress this year. Put in more hours than the last 2 years combined! Still doing metal fab/body mods. Have the side doors hinged and latched. Have the rear right door hidden hinges installed. Just cut out the drivers side rear wheel well and rear corner so I can install the new replacement panels and stretch the wheel well. Post some new pics soon.
Old Nov 4, 2014 | 02:45 PM
  #58
BudRacing's Avatar
True hot rodding at its finest!
Old Nov 5, 2014 | 02:02 AM
  #59
E36LUVA's Avatar
OMG this is so awesome!
Old Nov 8, 2014 | 10:45 PM
  #60
franktf's Avatar
Simply Badass!!!!!
