Possible 99 Volvo V70 conversion??
Old Apr 17, 2013 | 10:45 AM
mattsk8's Avatar
Default Possible 99 Volvo V70 conversion??
I've loved these wagons forever. I'm going to look at a potential car tomorrow, it's a 99 AWD V70 w/ 170k miles.
I would like to do a 5.3 auto conversion.
Can anyone help steer me towards getting my feet wet w/ this, plus help me start counting some costs?? Anyone here done this conversion?
Old Apr 22, 2013 | 10:39 PM
philntx's Avatar
Scroll down about 1/2 way through this thread. The steering rack is in the same position where the transmission of the LS engine would go. Not good.
http://grassrootsmotorsports.com/for...s/55366/page1/
Old Apr 23, 2013 | 03:15 AM
axelg89's Avatar
Enough time (&money) and anything is possible.. This is a local guy here in Sweden, not much left of the original car but it's a cool build.
http://www.garaget.org/?car=209785
Old Apr 24, 2013 | 08:18 PM
White Out's Avatar
You'll have a much easier time with a 240, 740, or 940. The 850/V70/S70 chassis is FWD based.
Old May 20, 2013 | 08:49 AM
mattsk8's Avatar
Thanks for the replies.
I actually bought this 99 Volvo V70 R. It's AWD.
Not sure what I'm going to do. I found out the original 5 cyl turbo engines are fairly capable, so I'm going to play w/ that first and if I blow it up, then I'll do the conversion.
Right now I have the bumpers off and the interior torn apart. I'm refinishing the bumpers (the flat black looked awful). I'm also recovering the headliner and fixing some other things in the interior.
(The ghetto turn signals are going way too!!)
Old May 20, 2013 | 09:29 AM
1CAMWNDR's Avatar
It doesn't matter that your car is AWD. The chassis platform is designed as a FWD. They just added a shaft to the rear for AWD. It is designed for a transverse mounted engine and transmission. I am not too sure you can swap a 5.3/4L60 into that car.
Old May 20, 2013 | 10:15 AM
mattsk8's Avatar
I know it won't be easy. This is a 95 or 96 850. It basically shares a very similar drive train. I am good at fabricating, was just hoping someone here has done this so I could know what I'm in for.
Old May 20, 2013 | 01:21 PM
1CAMWNDR's Avatar
OK. I didn't realize Volvette started as a FWD platform. If you have $$$$$ and fab skills go for it .
Old May 20, 2013 | 01:26 PM
SWAGON's Avatar
Would love to see it. I have an 04 V70R. I dreamed of this swap too but knew the time and money would not be worth it. That being said, this is my 2nd Volvo and I will never own another. I wish someone would just drop my VR off a cliff for me so I could collect insurance monies
Old May 20, 2013 | 02:01 PM
mattsk8's Avatar
I was looking for a 01 or newer body style until I started reading up on all the headaches involved w/ those cars; electrical and the auto transmissions seemed to be their biggest failure. From what I've read, they're nothing like the older 2000 and earlier ones were. Too bad, because your R is sweet looking IMO.
Also, there was a guy that did a swap in your body style, but it was a HUGE project. He had to cut the bottom out of just about the entire car and fabricate everything from the front to the back, including floor pans, engine cradle, front suspension, etc. I think it was in Europe that he did it, I found it just doing some searching. After looking that over I decided to steer clear of that body style! That's not to say mine would be easy by any stretch, but not as challenging as doing your body style!!
Old May 20, 2013 | 02:05 PM
SWAGON's Avatar
Yeah, all he did (well not all exactly..) was put the shell/body on a custom frame etc. Sick though.
The AWD angle gear, 4c shocks and ABS system are the biggest pains. And the suspension sucks for as advanced and expensive as it is. I love how comfortable it is and how it looks though. I wish it didn't have all the annoying issues.
Old May 20, 2013 | 02:09 PM
mattsk8's Avatar
After re-reading this thread, it was this post that had the one from Europe. Would be sick, but I'm not sure I'm down for all that work.
Old May 20, 2013 | 03:28 PM
rotor vs. piston's Avatar
http://www.youtube.com/watch?v=GFrPjMVhP04
Volvette started as 1989 745, RWD from factory.
Old May 20, 2013 | 04:25 PM
mattsk8's Avatar
My bad, you are correct. I thought it was a 850.
http://www.theantiteam.com/www.TheAn.../Volvette.html
Old May 20, 2013 | 07:25 PM
What I would do is find a pick n' pull junk yard and go there w/ a tape measure and note pad. The subframes might not be that far different where you can actually use an older RWD car's subframe in your V70. Might have to swap front suspension for the steering pick-up points too.
Biggest thing I'd worry about is having enough room in the transmission tunnel and enough room in the rear to fit a pumpkin that will hold the v8.
Old May 21, 2013 | 10:20 AM
SWAGON's Avatar
That would be the biggest problem I think. The FWD w rear wheel assist Volvo's are still tranverse mount.
Old May 21, 2013 | 11:23 AM
mattsk8's Avatar
Very good advice, thanks! I'm sure I would have to rebuild the trans tunnel to hold either a 6 sp man or a 4L60.
There was a V70 I found that had a LS3, but no info. I need to do more research and see if I can locate this guy.
Old May 22, 2013 | 10:46 AM
onetype's Avatar
Too much work. Unless you want to make your own trans tunnel and custom linkage. Go with an earlier Volvo, they look much better IMO. That's why I did it in my 245, and I DD my v70R.
Old May 22, 2013 | 12:16 PM
mattsk8's Avatar
The further I look into it the more I agree. I also have a 75 Datsun 260 that, IMO, would be a better car for the swap. Just thought I'd check and see what's involved.
From the research I've done, I would have to build a trans tunnel, a custom engine cradle, complete front suspension, then deal w/ the rear diff. It would be a unique car when it's done; but so would the Datsun.
Thanks for all the input!
Old May 22, 2013 | 02:12 PM
Are you sure you saw a V70 conversion or was is a V90, which looks like the more modern volvo's but is basically the same as the old RWD 940's.
It's hard being a trailblazer, just have to decide if it's really worth it for you when you account for your time and of course the money it would take.
I sure wouldn't be mad to see another v8 z running around
