mustang headers
Old Apr 28, 2013 | 11:32 PM
bigchief52780's Avatar
Default mustang headers
Mustang swappers need to check out the 45840 heddman swap headers for the foxbody. they are easy to install and have plenty of clearance. easy bolt up and spark plug access. they are half the price of the kooks and dynatecs.
Old Apr 29, 2013 | 07:43 AM
booboo37's Avatar
But do they dump right at the trans crossmember like the Kooks ??
Old Apr 29, 2013 | 09:01 AM
protracracing's Avatar
Originally Posted by bigchief52780
Mustang swappers need to check out the 45840 heddman swap headers for the foxbody. they are easy to install and have plenty of clearance. east bolt up and spark plug access. they are half the price of the kooks and dynatecs.
What K-member are you using?
Thanks
Dennis
Old Apr 29, 2013 | 09:13 AM
TopNotchLSX's Avatar
Any pictures of them mounted? Around the important areas possibly?
booboo37...just googled them. They are a mid-length exiting near the bellhousing
Old Apr 29, 2013 | 05:30 PM
i will get some later today. they dump right where trans and motor bolt together. i am using the qa1 kmember with stock a arms. made my own motor mounts. pics are coming.
Old May 1, 2013 | 10:09 PM
Default pictures
headers
Attached Thumbnails mustang headers-lo.jpg   mustang headers-20130429_183103.jpg   mustang headers-20130501_182736.jpg   mustang headers-20130501_182819.jpg
Old May 2, 2013 | 06:24 AM
booboo37's Avatar
So the steering shaft goes on the outside of the tubes and not through them like Kooks ?
Also is easy to get to all the plugs ??
Old May 2, 2013 | 12:27 PM
I have been wondering the same but it looks like the shaft will pass between the tubes.
OP...did you install your steering shaft yet? Thank you for the pics
Old May 2, 2013 | 09:27 PM
64post's Avatar
Some mustang swappers like myself don't really want headers with ball socket/flange connections. No Thanks, full length Dynatechs make more sense and offer 1 7/8's primaries.
Old May 2, 2013 | 09:49 PM
LS1_PNY's Avatar
Yes OP have you put the steering shaft on? And not to thread jack does anyone know how much horsepower you would gain or lose over full length to mid-length?
Old May 3, 2013 | 11:40 AM
It's not too hard to chop the end off and weld on a V-band at that point. It's nice to have other options and these would offer more room around the bell housing for the rest of the exhaust.
Old May 3, 2013 | 12:24 PM
steering shaft goes thru the headers. i did but not in this picture. i like all the extra room. easy to get to starter and trans. it also looks like the motor can be pulled with headers still attached.
Old Jun 21, 2013 | 09:09 PM
TxFireman1972's Avatar
Any pics of the completed exhaust?
Old Jun 22, 2013 | 03:17 PM
LQnotch's Avatar
will these work with team z k member i bought dynatechs and they wont work
Old Jun 22, 2013 | 03:31 PM
Dynatechs definitely work with the Team-Z. You sure you have the motor mounts on right? Whats not working?
Old Jun 26, 2013 | 12:34 PM
Default hedman headers foxbody
header pics
Attached Thumbnails mustang headers-20130625_182724-2-.jpg   mustang headers-20130625_182733.jpg   mustang headers-20130625_182751.jpg   mustang headers-20130625_182759.jpg   mustang headers-20130625_182809.jpg
Old Jun 27, 2013 | 04:47 PM
Do you have any pics showing the steering shaft with the headers?
Old Jun 28, 2013 | 08:35 PM
racerrit's Avatar
nothing u buy will ever fit one hundred percent. remember we are putting **** together that was not meant to b. And even if it was theres always fab work to do building street or strip cars. The kooks make the most power hands down u just need to weld a couple angles together to clear the crossmemeber. i have 3 in exhaust and we wrapped it right around it. any good exhaust guy can do it. my little ls2 with ls3 heads makes big horse with theses headers
Old Jun 28, 2013 | 08:40 PM
Well thats a given. I was just curious to see how it looks around the steering shaft.
Done anything else to yours lately?
Old Jun 29, 2013 | 10:45 AM
i will get that steering column pic tonite. took the car to the track thursday and it was like a ghost got in it. car would not run right for ****. it seem like it was trying to overheat. ran fine the day before and that morning. thinking bout going back carb and selling all my efi stuff.
