5.3 INSTALLATION IN 72' CHEVELLE 'help'
72' Chevelle
05' 5.3 vortec / 4l60e
Holley pan
Chevelle narrow frame mounts with Energy Suspension engine mounts.
I've got my 5.3 set back about an inch in mine. No accessories, no rad, no fluids, no batt...I'm at about 5 degrees...
72' Chevelle
Holley pan
What conversion mounts are you using? Holley? 1in back? You also need to keep an eye on tie rod clearance.
Kerry
Using stock narrow frame mounts and poly motor mounts with an adaptor plate.
I checked the engine angle again and it is right on 6 degrees so I hope that the weight of the front clip, exhaust maifolds, alternator, oil and water along with sitting on a flat surface will result in somewhere around a 4 degree angle.
Suggest you reseach Drive Line Angle or Setup..here are a few articals to start with..
http://www.4x4wire.com/toyota/tech/driveline/
http://www.4xshaft.com/driveline101.html
Oh, BTW.. the Floor pan support/cross brace can also be in the way of the Yoke/U-Joint. I had to use a BFH on it to flatten it some. Others have had to cut it out and make a new one that is higher and re-enforced.
BC
In order to set the driveline angles, you need to be paying attention not to the angle of the engine with respect to gravity, but the front and rear operating angles. The front operating angle is the angle between the output shaft of the transmission and the driveshaft. The rear operating angle is the angle between the pinion gear and the driveshaft. The front and rear operating angles need to be equal, but opposite and also as small as possible without being zero.
On a GM a-body with a LS engine, you essentially need to raise the back of the transmission as high as it will go. If your car will be lowered, you may still run into a situation where the front operating angle is too large. This happens because when these cars are lowered, the rear axle rides higher inside the body. This causes the front operating angle to increase. By adding adjustable rear upper control arms, you will be able to make the operating angles equal, but you will not be able to reduce them. This will likely result in operating angles that are more than 3 degrees, which I guarantee will cause a high speed vibration. This is one of the dirty little secrets of a-bodies that are lowered.
Andrew
I can tell you with confidence, that if you plan on lowering the rear of the car at all, you would be best off to raise the back of the transmission as high as it can go. You will be limited by the slip yoke making contact with the floor boards.
Andrew
