3 fuel lines WTH?
Old May 5, 2013 | 09:06 PM
southerntidefan's Avatar
Default 3 fuel lines WTH?
I'm getting to the fuel side of my swap and I have 3 fuel lines coming out of the engine what is what? I've read about return lines but only one. I have 3 lines that run to intake from rear of jeep. This is a 5.3 supposed to be from 04 suburban but wiring harness has blue and red connectors and get.
Old May 5, 2013 | 09:11 PM
Atomic's Avatar
I need a gauge for that
One is probably the evap line from the gas tank to the intake.
Old May 5, 2013 | 09:14 PM
Sorry something cut me off. im sure I'll have more questions as I go, thanks for the help. FYI one line is 3/8 has filter on it, two are 5/16
Old May 5, 2013 | 09:16 PM
Oh OK. Makes sense. Should I tee it in with return line? Or do away with it?
Old May 5, 2013 | 09:18 PM
Roll Tide by the way
Old May 5, 2013 | 09:44 PM
i r teh noobz's Avatar
EVAP can be removed if you don't have to pass emissions testing. If you keep it, it does not connect to the other lines in any way. It vents the fuel tank vapors to the intake manifold.
Old May 5, 2013 | 10:03 PM
Cool thanks. I guess next question is which one is evap? The 5/16 line coming out of top of intake or the other?
Old May 5, 2013 | 11:37 PM
ls1nova71's Avatar
The one coming out of the top of the intake that's hooked up to the purge solenoid is the one to remove. The return line will be hooked to the fuel rail under the feed line.
Old May 6, 2013 | 03:54 AM
Thanks. Very helpful very quick
