bbf or lsx swap fox
Use a AJE k-member with there LS motor mounts and AJE trans cross member with Dynotech conversion headers...
i am running a walbro 255 with my setup. 6.0/ls6 heads/comp cam/42lb injector/ 92 mm tb/ ls2 intake
So I can just put a bigger pump in the tank and use my current lines?
Also, I want to run a auto trans.
I cant find a 6.0l anywhere local. The nearest isnabout a 45-60 min drive. They want $1100-1800 for the 6.0. That ranges from 80-200k+. Ive used car-part.com. is there any other sites I could use besides ebay?
You can take a lq9 and put the ls3 top end on it, then put a healthy cam in it and make darn near 500rwhp CAM ONLY, with a stock ls3 intake! There was a fella locally that made close to that with almost that exact setup.
The tunalbility is another advantage, you can make the engine run perfect with little headache!
Then there is the ease of getting it running. $450-$525 for a harness (from us.) If you keep it simple and go drive by cable. Easy 4 wire hookup, hit the key, and listen to her run!
The advantage to this swap is that there have been several guys do this swap, so there is a ton of info and threads on this very swap.
Bill
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
