2pc case 4l60e with 4472 awd xfer case
Ive done some searchin here and on the web, of course with no luck![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Swapping lsx into a 4wd s10 blazer, but going all wheel drive. I have a 700r with the 4472 awd xfer case, and a 2pc case late model 4l60e, that I want to use the awd transfer case with. Is there an adaptor that will mate the 2pc 4l60 case(6bolt tail housing) to the 4472 style xfer case????
Also, will the output shaft from the 700r4 work in the 2pc case 4l60e case????
You might be 7 years too late...
