Basics for a LS swap into a 1990 Chevy C1500?
Old Jul 13, 2018 | 11:31 AM
  #41
Melvin Wayne Carter's Avatar
Default Same question
I have a 94 k1500 4l60 got a 5.3 ready to go in what do I need to use stock trans
Old Jul 13, 2018 | 11:47 AM
  #42
slogo's Avatar
Look at post # 12 check that site out.
Old Jul 18, 2018 | 03:48 PM
  #43
CHIVOBLING's Avatar
Good stuff
Old Nov 4, 2019 | 05:47 PM
  #44
Harold Gerig's Avatar
Im also looking into doing a swap on my 94 gmc 1500 I have been debating on upgrading to a 4l80e was there much modification needed to the trans tunnel and drive shafts as well as the shift linkage if and when I do the swap I plan to get the trans and engine as one unit
Old Nov 4, 2019 | 07:07 PM
  #45
Tuskyz28's Avatar
Never thought GMT 400 trucks would get all the rage they are getting.... proud owner of my 97 3/4 ton.
Old Apr 26, 2020 | 07:46 PM
  #46
Sea bass Chukwu's Avatar
Default Fuel pump
Originally Posted by bustac
We swapped a 2001 5.3 into 1989 Silverado with a 4L80e, used generic swap plates with the 305 mounts. Used some generic mid length headers for 2001 Silverado. Ran the factory 5.3 harness with the underhood fuse panel only 4 wires to hook up 12v to fuel, PCM, ignition.
Attachment 608462
what fuel pump did u get
Old May 2, 2020 | 11:28 AM
  #47
Josh Price's Avatar
Default 1991 chevy Silverado 5.3 4l60e
I seen someone say they used 2001 chevy Silverado headers on there swap will they for sure work. Does anyone know for sure
Old Sep 12, 2021 | 05:07 PM
  #48
alexisgraham8's Avatar
Default Questions
Attachment 608462
hi! I’m trying to do the same thing with my 1990 Chevy 1500, I bought a parts truck with motor and trans but thought I needed a new wiring harness. You used the original?
Old Sep 20, 2021 | 03:54 AM
  #49
gagliano7's Avatar
You can use the 5.3 harness but you need to modify it. I went with a pre made harness from BP-Automotive and you only need to connect 4 wires. I did my swap back in 2011. If i was going to do it today i would use the holley terminator X setup. Way easier to setup and if you want to upgrade cam or heads much easier to program then buying Hptuners and learning or spending money to have someone tune it everytime you make a change.
Old Feb 3, 2023 | 02:30 PM
  #50
Ethelms's Avatar
More info needed on your end. Using your stock 1990 trans?? etc...Swap plates (1" setback) OEM LSx truck FEAD, OEM ECM & harness. Easiest swap would be a complete dropout from a DBC motor. Try a SEARCH and buy a LS swap book.
I'm doing the same oname a 88 firebird it was a 305 tbi I'm putting a 200 5.3 truck engine in with the Trany from the truck as well I got the engine in I'm having trouble with the wiring do you have digram for what you did with the factory harness wiring in the factory badges I'm no expert I'm just getting started
Old Sep 21, 2024 | 07:23 PM
  #51
marthagomez81's Avatar
Attachment 608462
What about the throttle body I have have a wired one
Old Sep 21, 2024 | 10:14 PM
  #52
You really need to check the post date when you reply to a two year old thread. bustac hasn't been here for over 2 years
