Have i gone mad?
Thanks
Rocky
Does anyone know what oil filter fits the Holley pan? It's thread was bigger than the vet factory filter. Also what trans stick are you guys using with the vet style covers. I have a truck stick that came with the 6l80 but not sure it will work.
Thanks
Rocky
[/URL
[/URL
[/URL]
[/URL]
[/URL]Sent from my iPhone
the PF48 should be the correct filter. If you want to stick with the PF46.. you can just pick up or use the threaded adapter from an older pan tbat is using the PF46. You can use the LS2 one
I used the Lokar tans tube and stick.
I had a small stock of the PF46's so I did the adapter swap fir now and will switch to the upgraded PF48e later on both the Chevelle and Nova.
Keep the thead and pictures coming !
BC
[/URL] Rocky
[/URL] The vet engine has fit perfect. The vet donuts are 2 big but the engine stands are in a perfect location to the frame. I found after market donuts that will work. Ill be fabbing frame mounts tomorrow. I used 2010 camaro manifolds and Holley pan both fit nicely.
Jimbo it's a miller ill have to look at model number. It's a small one.
[/URL]
[/URL]
[/URL]
[/URL]
