Looking for a replacement connector pin..
Old Sep 9, 2013 | 08:52 AM
72chevelle6.0's Avatar
Default Looking for a replacement connector pin..
I am hoping that you guys can help me.
I have a GTO that has a damaged terminal in the connector that plugs in to the throttle position controller and I have been looking high and low for a replacement with no luck.
here are the picture of the connector and the controller along with the part of the damaged pin that I could get out.
Old Sep 9, 2013 | 11:42 AM
68 SS's Avatar
I think I have a few of the terminals I will have to look when I get home from work and let you know. If it helps they are Bosch standard terminals (I was a BMW tech for years) they used them on tons of european cars. If you have a BMW dealer close I would be willing to bet they have them in stock.
Old Sep 9, 2013 | 12:16 PM
I don't have one real handy. so if you have some that would be awesome.
Old Sep 9, 2013 | 12:43 PM
BOXCHEV's Avatar
What are you going to use to crimp it back on?
Old Sep 9, 2013 | 12:46 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I may have one of those connectors laying around with a piece of wire on it after it was cut from a harness that we were rewiring. Ill take a look. That way you dont have to crimp it, you can just solder the wires together.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Sep 9, 2013 | 12:48 PM
68 SS's Avatar
They crimp with the standard weather pack crimpers. I will let you know tonight.
Old Sep 9, 2013 | 12:53 PM
LS1Tech Sponsor
This is true. However, when using a repair tool you are supposed to solder the crimp also per repair manual J-38125.
This goes for the metripack/weatherpack terminals also.
The bosch terminals can be a bear to find though. Unless you work at a BMW dealership.
__________________
1-888-467-4491
Old Sep 9, 2013 | 01:15 PM
I always solder my crimps also. it just makes me feel better about the crimp.
Old Sep 10, 2013 | 08:10 AM
68 SS's Avatar
I have a few of them put my hands on them last night, PM me your address and I will drop them in the mail.
