Alternator only?!
Old Sep 15, 2013 | 04:48 PM
thePunkville's Avatar
Default Alternator only?!
I've got a ls2 with ls1 crank an alternator, but have electric water pump an power steering! So I only need to run the alternator ? How would I set this up? I don't know what to search for the alternator sits on the lower right an only has a idler pulley on the bracket. So does it need a tensioner?
Old Sep 15, 2013 | 07:05 PM
soundengineer's Avatar
You either need a tensioner, or you need an alternator bracket that is the tensioner(like the CBR relocation bracket)
Some people just put a manual tensioner in place of the lower idler pulley.
Old Sep 17, 2013 | 05:03 PM
How would I do this?
Old Sep 17, 2013 | 05:06 PM
Which one? I mentioned multiple things.
Old Sep 17, 2013 | 06:17 PM
i r teh noobz's Avatar
You might be able to find a stretch belt in the correct size. The 09-up trucks use them for the AC compressor.
Old Sep 17, 2013 | 10:41 PM
a couple of people also make a bracket to replace the stock one with one that has a Turnbuckle/heim joint setup...the bracket is the tensioner...
made for guys just doing alternator only..
Old Sep 21, 2013 | 05:23 AM
This sounds like what I need!!! But can you link me to some info or explain a little bit more in detail
Old Sep 21, 2013 | 05:52 AM
Try aeicnc.com
Bob has one that mounts passenger side..
And here's an example from yellow bullet
http://www.yellowbullet.com/forum/showpost.php?p=5173383&postcount=5
Old Sep 21, 2013 | 07:19 AM
garys 68's Avatar
There are a few out there, try BMR
http://www.bmrsuspension.com/?page=p...d=56&catid=149
