Holley LS oil pan hitting frame - Help
Thanks Turtle, I do not have the time or resources to be cutting the frame or the money to buy another pan. I am going to try a combination of using a 3/8" plate to go between the mount and swap plate and/or a "tall and narrow" motor mount. I am taking a day off tomorrow to give it another try. I am also going to see if moving the engine .5 inch forward will help with it hitting the firewall.
The new Hooker engine and transmission mounting and exhaust components resolve that common issue as well. You can use the standard small block heater core with no problems as well as the stock A/C suitcase if you wish. This image shows the passenger side mid-length header (long tube header has same clearances) installed using our new mounts. Look closely and you will notice something unique about the engine mount. It's a 72'-up clamshell mount retrofit into a 1st-gen F-body/3rd gen Nova...goodbye frame stand compatibility/installation headaches.
But like all solution.. there is a pro and con.. in this case, moving the engine forward would cause contact with the engine pan and the crossmember.. the solution to that would be to raise the engine. If that location of the engine/trans it works, then good for it.
Personally, I see no reason that a Clamshell mount wouldn't work.. it just comes to complete installation and what will work or not. They use the same three bolt hole configuration on the block.. so it just comes down to mounting the frame stand for a Clamshell mount... but alignement is still the majore concern.
As with all that is having a problem, i would suggest bolting the plate, mount and frame stand all together on the block and test fit the placement into the frame/subframe.. and then make any adjustment of spacer or what not. Also making sure the engine is level and center (or offset if that is what is needed).
Also.. for my Nova.. 1/2" rear is what worked out best for me... but like any swap.. what works for other, might not work for you.. you just have to work around anything that presents any issue. It is anything that can't be worked out.
BC
By Hooker (or any vender) moving the engine forward. Yes it would leave space between the firewall and engine/head and therefore allow you to use the non-BBC heater core.. that is a solution..
BC
BC
I am starting to think Toddoky is pretty well versed on the 67-69 camaro/ 68-74 Nova chassis, haha.
I have the holley swap pan in a 70' nova and the pan was pbarely touching the crossmember, you could actually get the bolts in but I did not like the idea of the pan contacting the subframe as the engine moved around, so I notched the subframe approximately 1/2", which was more than enough. Considered washers, spacers, ect but I was happy with the engine position otherwise and I did not have any other clearance problems. It is very hard to notice the notch with the motor installed in my opinion.
It sounds like holley will have a nice matched package for this chassis before too long, but I got started a long time ago. Another option is the Mast pan, the dimensions are available to see if that would solve your issue.
Is the new Holley mount location high enough to use the compressor in the stock location? I am a fan of stock component locations especially the compressor. There is a reason that all the manufacturers are running the compressor off of the damper.
After being into my conversion for about 4 years I have seen enough to know what everybody is saying you will more than likely give up something up. I do like what I am hearing but will reserve judgement for other people coming along. It should be easier and better than trying to piece together a number of different parts to make the conversion work especially when you are in the 'discovery' mode where part combos don't quite fit right. Some pics of the new pan and motor installed at different angles would also be nice. I am sticking with the original designed pan since it will give me what I want though......too late to change any direction.....
Yes bczee, you would normally have contact issues between the pan, crossmember and/or steering centerlink if you moved the engine forward, which is exactly where the new designed Holley F-body pan comes into the picture. The new pan has all the fitment benefits of the notched 4th-gen pan that so many have used in an LS swap without the oil capacity loss penalty that comes with using one (the new Holley pan holds 6.2 quarts with the filter). The clampshell mounts have no alignment issues whatsoever as we are using proprietary engine brackets developed specifically for this application, not GM clamshell brackets and adapter plates. The brackets have notched ears like the stock brackets that let you drop the engine right down on the mounts and then easily install the through bolts into them. I've had the prototypes installed in three different vehicles with the engine and transmission and the combo goes in like butter each and every time. Here's a photo of the mock-up to give you a better idea of what's involved with the mounts themselves...the plates bolt to the subframe with two countersunk head bolts in each that install in stock holes in the subframe and then the clamshells bolt to the plates with two bolts again going through the subframe and two hanging off the back like the stock 73-74 Nova clamshell set-up. It works fantastic...frame stands, old-school mounts, shims and spacers can all be removed from the needs list of this swap now if you don't want to mess with the headaches associated with them.
I have talked to one Holley sales rep in the area at a local car show and do talk with Liz Miles once in a while....she lives in the area and I am looking forward to getting my hands on one of the new pan to replace the pan I have in my Chevelle... as I cracked my CTS-V pan last year.. and put in a notch F-Body pan (that is not completely sealing and still leaking, so it is a winter project).
Yes, I agree with the clamshell mount would offer a larger area or margin of the engine and frame being out of alignement. .but if something is so out of wack.. even the clamshell setup is not going to help.
About to take on a new swap for my friend (2nd gen Camaro, if he commits) and a 40 ***** Truck.. so.. I am looking for Alternator only bracket and other stuff that may help. But most likely I will have to fab a bunch of new stuff or mod other parts. Well have to see what pan clearance I will encounter.
Keep them new parts coming!.
thanks.
BC
Ghost - I'll get to those pictures for you as soon as I get some time to get under the nova soon..
Toddoky
thanks.
BC
thanks.
BC
Todd
Notching the cross member to keep the compressor location works which is what you have to do anyway.
One last question what engine angle are you getting with this swap? I am curious. Currently I have about 3.5 degrees with the tranny mount pushed up about an inch. I can get it down a bit by lowering the front a bit but not much.
#32
Todd........When are the new pans going to be available???
Ken
Ken
#34
Update:
I was able to mount the engine by raising it 3/8 inch and moving forward 1/2 inch. This gives me plenty of space between the firewall and engine, also I am not hitting the SB heater core hoses (although I did crush one trying to get engine into the stock location).
FYI, I could have moved the engine another 1 inch forward and not hit the center steering link, there is plenty of room there. If you did move it that inch, you may have to raise the engine more since the Holley oil pan is sloped.
#35
For all those interested, I'm puttng together another mock-up of a 1st-gen F-body LS swap over the next couple of days with our new parts to photo document the fitment of the new Holley pan using a pre-production part I have on hand. I will post up some detailed photos for all to see once I complete the exercise. I'll also be loading a TH400 and a 2004R into the car to validate their fitment using our T56 crossmember and a spacer block to make up the mount pad height difference between the transmissions. The
mount location on the TH400 and 2004R share the same distance from the bellhousing mounting face of the T56 within 1/8", but the distance from the mounting pad machined surface to the centerline of the output shaft is closer, hence the need for the spacer block to maintain the same eng/trans inclination angle.
#38
Most will just pickup a cheap Angle Finder/gauge.. and attach it to the end of the output shaft on the trans.
Many will carry something like this, there are more costly one, but these usually will get you in the ball park. (Lowes, Sears, Homepot,etc)
http://www.harborfreight.com/dial-ga...der-34214.html
Would suggest you google serch "Drive Line Angle" for more information.
BC
BC
#39
BC
BC
