Twin Turbo LSx 6.0 Notch Project
Old 11-20-2013, 10:00 PM
  #41
baggedsvt's Avatar
Originally Posted by aknovaman
Where did you get the schedule 10 stainless pipe and elbows to build the headers? I would like to bod some for my jag swap.
Amazing, a mustang that's not a beat up piece of crap. Love it.
Treadstone and Mcmaster Carr have sch 10
Old 11-20-2013, 10:02 PM
  #42
baggedsvt's Avatar
Originally Posted by Busa_rob
What radiator and fans is that? Also what about the alternator and bracket? F body?
Alt is 2007 truck alt, the braket is a fbody with extra boss in block drilled and tapped for bolt and spacers for belt alignment.
Old 11-20-2013, 10:03 PM
  #43
dmracing's Avatar
what size tubing are the manifolds and how thick
Old 11-20-2013, 10:49 PM
  #44
silver01z6's Avatar
How are you going to reduce the extra air pressure generated by the turbo's?
Old 11-21-2013, 11:04 AM
  #45
baggedsvt's Avatar
Stay tuned for more pics. Gates will go right at the bend of the logs going up to turbo.
Old 12-01-2013, 08:43 PM
  #46
baggedsvt's Avatar
Some more progress. Gates are placed. Got driver side gate dump done. Got my Bradco 10" bolt together converter in so I mounted my BTE TH400 with RMVB and a brake. Used a AJE tranny crossmember and it all bolted right up. Started the driver side down pipe. Not too bad fit but will have to go on and off from the bottom. Exhaust will be straight through and run through a x-pipe right into polished straight tips rear exit. Also got a guy working on some new edge 5.0 style fender emblems but 6.0 instead. Should really confuse some people when done.
Old 12-01-2013, 10:51 PM
  #47
Busa_rob's Avatar
Looking damn good. What oil pan is that?
Old 12-02-2013, 09:03 PM
  #48
baggedsvt's Avatar
Mucsle car pan from summit. Only about 169 with pan,gasket, pickup, windage tray, and bolts. The 6.0 truck pan would have fit if you wanted.
  #49
baggedsvt's Avatar
Passenger side down pipe. Had to go back toward firewall and then down as mustang k members sits motor offset a little for brakes and steering.
Old 12-02-2013, 09:09 PM
  #50
baggedsvt's Avatar
Ordered up dad "me" some Christmas gifts on cyber monday.
No need for a 5 lug swap anymore with these in 15x4 and 15x10
Had to get this from team Z as well
Old 12-03-2013, 07:37 PM
  #51
baggedsvt's Avatar
All fab work complete in engine bay. Oil lines, boost lines, fuel stuff and harness are pretty much whats left as well as some paint work.
Old 12-03-2013, 07:45 PM
  #52
Sarg's Avatar
Very nice work! Makes me want to go twins!
Old 12-03-2013, 11:20 PM
  #53
95LSX454's Avatar
Beautiful Badass Build!!!! Great JOB!!!!!!!
Old 12-04-2013, 08:51 AM
  #54
static low 92's Avatar
Talk about some tight space.
Any worries about baking paint on the inner fender structure? Are you wrapping the downpipes?
Btw looks great. Super clean work man
Old 12-04-2013, 08:54 AM
  #55
schreurs1's Avatar
Looks like a work of art. Beautiful build.
Old 12-04-2013, 12:02 PM
  #56
AmishAssassin's Avatar
Outstanding build and I hope when you got the wing you ordered a parachute with it.
Old 12-10-2013, 05:42 PM
  #57
baggedsvt's Avatar
All fab work complete just finishing up the exhaust mid pipes. This is the engine bay before it goes in to paint for some more detail. Down pipes are double wrapped in black. And had these 6.0 badges made chrome and mirror black modeled after the new 5.0 design. Gonna have to see them on car before I decide which I will use.
Old 12-10-2013, 06:02 PM
  #58
Rob Carlson's Avatar
nasty
Old 12-10-2013, 06:04 PM
  #59
dyno yet?
Old 12-10-2013, 06:15 PM
  #60
baggedsvt's Avatar
Originally Posted by Rob Carlson
dyno yet?
Still have some work before it fires up. Wont be on dyno until early next year.
Quick Reply: Twin Turbo LSx 6.0 Notch Project
