Twin Turbo LSx 6.0 Notch Project
#81
Finished my Pro Ratchet shifter install. I wanted to keep it in the stock shifter location. I could not drop the whole thing down deep enough to get whole body under my center console so had to trim the front. Covered it with a piece of black suede. Also my weld rts came and MT 275/60/15 Radial pros as well as M&H 27" front runners. Started tearing everything back down in engine bay to get ready for final assembly. Then comes wiring and plumbing.
![](https://lh3.googleusercontent.com/-4ZqPtnbdHls/Ut32BlIwBoI/AAAAAAAACFo/iYJTZiC07XU/w487-h865-no/IMG_20140120_232115_746.jpg)
![](https://lh5.googleusercontent.com/-Rf6Olu7wkkc/Ut32FXOfY0I/AAAAAAAACFg/cHFkyCwqnWw/w487-h865-no/IMG_20140120_232054_142.jpg)
![](https://lh3.googleusercontent.com/-Ymyis2A1rg8/Ut3532g3BZI/AAAAAAAACCs/6MtpL4WrOX4/w1538-h865-no/IMG_20140120_233414_799.jpg)
![](https://lh4.googleusercontent.com/-MfiAjsHGuN8/Ut356KSLeaI/AAAAAAAACC0/vOO8qB3ryBQ/w1538-h865-no/IMG_20140120_233420_910.jpg)
#83
Been a wile for updates but it has been the small things. Fuel lines, vacuum lines, boost lines, spark plug wires and such. It wont be too long now. All that is left is adjusting shifter cable, putting lower rad hose on, putting fluids in and then wiring everything up. here are a couple pics.
![](https://lh4.googleusercontent.com/-A_8HQcGRWgA/Uyz-GVBj5AI/AAAAAAAACIw/fQjjwzFSOMk/w1538-h865-no/IMG_20140318_231302_531.jpg)
![](https://lh4.googleusercontent.com/-ZmwUfV_6U8A/Uyz-E16_q7I/AAAAAAAACIo/AXh_jMmed9o/w1538-h865-no/IMG_20140321_203416_148.jpg)
![](https://lh4.googleusercontent.com/-l4sgkcCcQxI/Uyz-HSTL8DI/AAAAAAAACI4/rTR6nTf7crs/w487-h865-no/IMG_20140321_203329_883.jpg)
#87
Some more progress. Vaccuum lines all ran with 1/4 dot line and fittings are push lock. Oil feed and drains run. Breather lines run and tanks mounted. Fuel lines all hooked up to regulator. Plug wires and dei heat shield. over 1000 dollars in new fluids are in. Little decal added to front bumper to make people mad lol.
Pic without coil covers. I could never leave them off looks so ugly without them.
![](https://lh3.googleusercontent.com/-IVAwDQWgggc/Uy99sTosFvI/AAAAAAAACJQ/dy-tatyJKVQ/w1598-h899-no/IMG_20140323_203204_045.jpg)
![](https://lh3.googleusercontent.com/-1B8dW9AOgQg/Uy99uod1N9I/AAAAAAAACJY/uj8YUcXl5h8/w1598-h899-no/IMG_20140323_203246_062.jpg)
![](https://lh5.googleusercontent.com/-k3Io1EQrVcg/Uy991V0UlYI/AAAAAAAACJw/Drz6Q7Q4Hig/w1598-h899-no/IMG_20140323_203258_174.jpg)
![](https://lh5.googleusercontent.com/--2g84lhm3Uo/Uy993EV74GI/AAAAAAAACJ4/B2NCggr5Jfw/w1598-h899-no/IMG_20140323_203219_637.jpg)
#93
Takes time man. The little stuff takes the most time but makes the biggest difference in the end result.
#95
Im calling on3 here in about a hour and ordering mine, but im shooting for t70 turbos with .81ar housings.
Knock anything else out on your car over the weekend?
#96
Got the Notch all wired up thanks to BP Automotive. I opted for a brand new built harness from BP. The harness is oem quality with all wire color coded oem and all new oem connectors. Now I just need some E85 in the tank and a base map to fire it up.
![](https://lh6.googleusercontent.com/-e4X_Mvx6ttc/U0tjV2g4_pI/AAAAAAAACME/TsEoBs0hM7I/w1538-h865-no/IMG_20140413_233135_594.jpg)
![](https://lh4.googleusercontent.com/-mKUiJSlhijU/U0tjSoJ59zI/AAAAAAAACL8/EYuHGOng1_A/w1538-h865-no/IMG_20140413_233250_422.jpg)
![](https://lh5.googleusercontent.com/-XpxzL1KkMZ8/U0tjYKRMALI/AAAAAAAACMM/brB2iUoHODI/w1538-h865-no/IMG_20140413_233210_170.jpg)
