ls1 Fox swap
Old Oct 18, 2013 | 07:56 PM
Possum Boggs's Avatar
Default ls1 Fox swap
i have a complete 99 z28,frame is rotted has full bolt ons,i was wondering if anyone can give me a quick list on what i need to do a ls1 swap,looking for a quick detailed no bullshit list on what it takes to do it
Old Oct 19, 2013 | 10:13 AM
23_hellfox_23's Avatar
Ton's of foxbody swap threads!
But I will give you the run down that I have for my build.
If you have a complete drop out then your better off then most.
Because then you don't have to get the accessories, the trans, or the harness.
Now you will have to modify the harness for stand alone or to match up with the fox harness.
But with all of that being said.
Depending on your budget, just get the radiator from the z28 and fans.
Or buy a new one completely.
But you will need the k-member/mounts, trans crossmember, and driveshaft for the big things.
Other than that it is the little things.
Fuel lines, pump, filter, probably just use the gauges from the z28, headers or use manifolds and have the mid pipe made so on and so forth.
That's all based on you having the complete z28.
http://secure.ultracart.com/catalog/PSI
http://www.ajeracing.com/mustang.php
http://www.teamzmotorsports.net/Default.asp
Those are the main sites that I use for parts.
First link is for the stand alone and such, second link has tons of great suspension very popular for this swap, and the third has all of the suspension as well as headers and stuff like that.
Good luck with your build hope this helped.
DON'T FORGET THE SEARCH BAR.
Old Oct 22, 2013 | 02:06 AM
thanks alot Hellfox23
Old Oct 22, 2013 | 10:56 AM
If you don't make the swap I'll take that Z28 off your hands haha.
Old Oct 22, 2013 | 09:17 PM
lol you dont want that thing,its a rust bucket
Old Oct 23, 2013 | 12:40 AM
Chassis doesn't matter.
I would kill to have a decent donor for my swap haha.
That is a completely donor.
Old Oct 23, 2013 | 08:31 AM
id sell the shell
CHEAP
Old Oct 23, 2013 | 08:33 AM
Don't want the shell.
I want the drive-train, wiring, etc.
That's the point of a donor car haha.
Old Oct 23, 2013 | 01:06 PM
lol oh im gna keep that,hey would it be easier if i used a carb instead of EFI
Old Oct 23, 2013 | 03:01 PM
Easier?
I don't know a whole lot about carb so I don't know about that.
But like I said you already have the donor car, which means it's EFI so stick with that unless you just so happen to have a carb setup.
I've tried to dial in a carb and for me it sucked I wasn't that good with it.
Now with EFI it's just using a tuning software to tune it.
Maybe a more experienced person will chime in on that.
