best year e38 ecm for swap
also
do these ecm's have the ability to control the ses light directly? also do they have a tach output?
can cruise be made to work?
also because its a 6 speed car i will have to control the reverse lockout, so i assume i need to run a manual car os anyways.
You don't "have" to control the reverse lockout for the transmission, but you will have to press hard to the right to get the car in reverse.
I can't remember what is necessary (if anything) to run a manual transmission with an E38 since they use a TCM to control the auto functions. You may want to search the programming and diagnostics section for that answer.
my question was in regards to what ecm would be better, the 07 or 09+ for 20$ more
As mentioned before, GM is always updating the calibrations (program) on those things. The ECM will be physically the same, but the operating system running the calibration on it could be different. This sometimes changes what you can or can't do within the calibration.
In a simple word - yes, both will work fine. If you want to nerd out and do fancy non OEM stuff like run it boosted with a custom aftermarket OS, the older or newer operating system may be better depending on what you are doing. Honestly, if it's just going to be sent to a tuner and run pretty much stock, save the $20 and use it somewhere else like pretty bolts or wire loom.
