Column shifter 67 camaro resto mod
https://ls1tech.com/forums/conversio...-ls1-a4-6.html
I checked out both Lokar and Shiftworks.. the both had kits to use a straight rod from the column to the trans. But since I moved the engine/trans back.. the Firewall would not allow me to use them. you need a straight line of sight between the two. I didn't want to go the cable route.
So.. I re-engineered my Nova PG setup. Had to move the pivot mounting, create new adjustable rod's and modify the pivot link to extend the width and connection points. Then it was just a matter of getting the right Ratio / Rod Lengths which too a lot of trial and error of adjusting.
Good Luck. .if you have any questions. Just ask ..
BC
Be sure and check out how bczee did his...it's pretty slick...
I kept the column shifter on my 72 Chevelle wagon 5.3/4l60e...I also moved my drivetrain combo down and back.
I added a little length to the rod...and a couple extra bends to get it around the firewall...
BC
