E38 pedal options.
Old Nov 9, 2013 | 08:41 PM
ctd450's Avatar
Default E38 pedal options.
tube chassis rock crawler with a LY6/6L80 combo controlled by a E38 ECM and truck harness.
The truck pedal does not fit well in the footbox of the chassis (engine doghouse goes back to the center console) due to the curved shape. With Gen III pedals I just cut the curve out and weld it back together straight, but this pedal is plastic.
I know Mast uses the 'Vette pedal, but what other cars can I use a pedal from, which are straighter in shape, and that will work with this PCM?
Old Nov 9, 2013 | 08:45 PM
1989GTA's Avatar
I don't think you are going to do much better than the Vette pedal. It is smaller as in the bulk of it than the rest of those I have seen.
Old Nov 9, 2013 | 09:51 PM
71403's Avatar
2007 Monte SS pedal, p/n 15831256
Details here:
https://ls1tech.com/forums/conversio...-corvette.html
Old Nov 10, 2013 | 07:36 PM
ctd450's Avatar
Thanks for the link, very helpful.
Old Nov 13, 2013 | 02:17 PM
Tommy69z's Avatar
The new number is 25830024....any one found a source for a plug?
Old Nov 14, 2013 | 09:19 PM
ctd450's Avatar
Would EFI connection have it? Thanks for the new part #
Old Nov 14, 2013 | 11:07 PM
1989GTA's Avatar
I know they have the Corvette pedal there as that is where I bought mine.
Old Oct 16, 2014 | 11:40 AM
BLWN1's Avatar
What about the CTS-V pedal? Will it plug and work?
Old Oct 16, 2014 | 12:40 PM
CBM Motorsports's Avatar
We use pedal part number 25830024 for the E38's. It has a metal shaft. If you need a plug and pinout for it, we have that too!
Old Oct 16, 2014 | 02:17 PM
BLWN1's Avatar
So the other pedals Arent direct plug in?
Old Oct 16, 2014 | 03:06 PM
Most of the time if the plug is the same as the original, it will work. There are a few differences but I can't remember which ones they are off the top of my head. Some pedals use only 2 tps sensors where others will have 3 tps sensors. Which plug do you have on your pedal? Is it the flat 6 pin?
Old Oct 16, 2014 | 03:10 PM
BLWN1's Avatar
I'll check, it's at my buddies shop. Thanks for replying I appreciate it
Old Oct 16, 2014 | 07:49 PM
ctd450's Avatar
I wound up using the corvette pedal, 25835421. Swapped pins D and F on the connector on my truck harness, and it works great.
Old Oct 16, 2014 | 07:51 PM
ctd450's Avatar
I found that with the Gen IV stuff (07+) the pedals all use the same connector, but the pinouts change a little.
Old Oct 16, 2014 | 07:58 PM
Alex Quick's Avatar
I used an electronic pedal made by Lokar in my 41 Chev with a L96 (6.0 from a 2011 Silverado HD) along with a 6L80. Maybe a bit expensive (around $500) but it was easy to fit.
Old Oct 16, 2014 | 08:11 PM
BLWN1's Avatar
Awesome. Where do you find pin outs for th pedals? 09 CTSV and 08 silverado
Old Oct 17, 2014 | 07:32 AM
ctd450's Avatar
Vette pedal I found on here. I was also going to use the Malibu/Pontiac G8 pedal and found the pinouts on another site, I think a Chevelle site via Google.
Old Oct 17, 2014 | 10:28 AM
BLWN1's Avatar
Pedal just arrived, 10379038, as stated plugs right into truck harness now I'm searching for both ok outs to see what I need to swap. Thanks so far guys.
Old Oct 18, 2014 | 04:12 PM
ctd450's Avatar
Looks like O.E. application is 08-14 Cadillac CTS. Not sure where to get the pinout. Maybe Alldata?
Old Oct 18, 2014 | 04:38 PM
BLWN1's Avatar
Trying to find access now to all data
