LS vs. "Old School" 350
Good luck with the project, keep us posted!
However, it is very mild if it's only making 507 HP. My father's 463 (.040 over) is also very mild (ported stock iron rectangle port heads, solid flat-tappet .586/.600 243/251 110 LSA 104 ICL, old Team G single plane, 950 HP, 2 1/4 hooker LTs, 10.5:1 CR), idle is healthy, but not very aggressive (iirc idle is at 850-900). Car went 10.73 @ 129 in a 3300lb '79 Malibu (4.10s, TH400). However, he's definitely not getting the gas mileage of an LS, lol.
Now a much less radical 264"LSx with only timing adjustments made on it's first tack outing went 11.327....Pretty damn good IMO and "should" be mid 10's once dialed in.
I'd say it's all in what parts you have.
The LS1? The carb is new, so I'm sure that helps, but it is big for the engine size (850 cfm) it still starts reliably in crappy cold weather (on a lightweight battery). It also puts out 380 HP and deosn't leak a drop.
Anywhere.
Parts are getting increasingly plentiful. Oh, and it revs to the upper end of the spectrum and stays there for a while without barfing. Even "low end" heads" breathe well, and I've got a minimum of 125 pound weight savings over an all-iron sbc. This is a STOCK long block. No mods or go fast parts. Stock. 380 at the crank with headers, carb and intake only.
Total engine investment = 2000.
I wouldn't say it's all in the parts, more so how all the parts come together in a solid combo.
By the way, I really dig your ride! My '68 was my first car when I was 15, then became my first hot rod when I was 18.
By, it all in what parts you have...I ment IF you already have a 350 use it...if you already have a LS use that.
LQ4 short block w/ LS3 heads (basically a LY6) Heads shaved .050, and an aftermarket cam on a 110 LSA due to the carb.
after rereading this thread I see im the 3rd person to mention leaks , it realy is nice to have an engine that does not leak
These shorty headers are a pain in the rear unless you get them extended by having an extension welded on, but other than that, harnesses are easy to come by with all the vendors offering them here for reasonable costs, and so many companies are now getting efi pumps into stock setups available because of the overwhelming number of LS swaps going on.
If you decide to go with an LS swap, make a couple modifications while its outside the car. Cam and valve springs would be my very first recommendation. Make sure you have every bit of info available about the donor vehicle and your engine when ordering the cam. With quite a few variables on cam sensor mount, pickup style, cam gear design, its will be critical to get the right cam ordered to make it easy for you.
Others will chime in with other specifics to be cautious of, but that is one that I just happened to think of right off.
The heads flow as much or more than most aftermarket SBC heads. The blocks are two to three times as strong. The stock internals are good for more power than most small block guys ever dreamed of making. With fuel injection and electronic ignition, they will idle better while making the same power. They will also get far improved fuel economy. Not to mention power capability. I swapped out my big block for a turbo LS. Not only will it make more power, but it will be my daily driver.
Just saying. You can't argue 40 years of technology. Want a simple setup? Go with the small block. If you want any real world use out of it, go LS.
