LS vs. "Old School" 350
Old Nov 29, 2013 | 01:04 PM
AutocraftHHFL's Avatar
Default LS vs. "Old School" 350
Hi All..... I'm a new member but have read this forum many times and know there is a lot of expertise out there. I'm restoring a 1959 El Calmino and am considering different options regarding the engine. I am curious as to the feeling regarding installing an LS motor vs. an "old school" 350. Thanks!
Old Nov 29, 2013 | 01:19 PM
RezinTexas's Avatar
the feedback you get on this site is going to be pretty one-sided, but what are your plans and goals for the car?
Having owned and worked on both types of engines, I'll never touch an SBC again.
Old Nov 29, 2013 | 01:43 PM
VandykeT/A's Avatar
IMO for something thats going to sit most of its life and only be driven to car shows I would do the SBC just for the simplicity. For something I planned to drive much at all and I cared about the performance I would go LS.
Old Nov 29, 2013 | 04:00 PM
Fastdriver1992's Avatar
LS is way simpler. no leaks. 95% of the gaskets are reusable. aluminum lightweight NO RUST!
in any category you want to compare the 2, the LS will always come out on top
Old Nov 29, 2013 | 04:02 PM
ironmanLS1's Avatar
It all depends on what your goals and budget is. I have two cars, a 72 nova with a SBC and an 02 camaro with a LS1. The nova is primarily a bracket car and with a nothing too fancy pump gas 400 it will run 10.90's all day. I also have a back up 350 SBC engine that will run 12 flat. With a cam and a few add ons the camaro ran 11.87 last summer and for next summer I am shooting for 11.50. I drive both on the street but as of now the camaro will have friendlier street manners.
If this is going to be a cruiser and you already have everything set up for an SBC I would keep it that way. If you are starting from scratch, ie prior 6 cylinder or something else then maybe consider the LS platform.
Old Nov 29, 2013 | 05:40 PM
Brian Hoss's Avatar
Like its been said, you'll find biased opinions here. Same if you go over to Team Chevelle and ask this same question.
Technology moves us forward. As we work, we learn better ways of doing things with better results. The LS is a culmination of that. Easier, cheaper horsepower than the traditional small block. WAY better fuel economy without giving up that gained horsepower. And the dependability of fuel injection and the benefits it brings to both of the afore mentioned.
I have two 67's. One Chevelle one El Camino. Both LS powered. I've had more fun with these as an LS than I ever did as big block or small block cars.
Now the LT1 is starting to crack into the market. The only thing that isn't available yet is cores from wrecked trucks and cars. But its coming. I'm about to finish up an LS build and most likely, its my last. I'm moving forward with the technology into the LT1 and I cant freakin wait!
Old Nov 29, 2013 | 07:14 PM
HeavyMetl's Avatar
Same here. I had several SBC's over the years with various transmission combinations. For just pure fun on the street, the LS is a blast. I've even daily driven my LS swap for a couple months (in a pinch) which is something I could never do with the previous 383.
Old Nov 29, 2013 | 07:15 PM
garygnu's Avatar
elderbrock sells a stand alone intake /ignition system for ls1 motors .makes it easier to swap them into older cars.you can find a 5.3 ls motor for $500.
Old Nov 29, 2013 | 08:16 PM
speedtigger's Avatar
Old School Heavy
I'll just leave this here......
https://ls1tech.com/forums/showthrea...819&styleid=25
Old Nov 29, 2013 | 08:19 PM
NnOoSsSs's Avatar
Yea definetly agree with the 5.7. Or any of the GEN III, but it just depends on what your goals are. I know it isnt hard to find parts for SBC or LS
Old Nov 29, 2013 | 09:10 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Welcome to LS1tech Autocraft! SEARCH will be your best friend around here.
If this car has no engine and you need to start from scratch, I'd say build a LS 6.0 iron block torquer motor. That '59 is a heavy car.
A SBC is SIMPLER than an LS and it's installation in your car would be easy. The LS engine would require at minimum an ignition controller, engine swap headers and engine swap motor mounts. Hedman may have what you're looking for.
Old Nov 29, 2013 | 09:28 PM
gjestico's Avatar
LS all the way, buuuut what is the frame like in that '59 ? Is it like a '55 chevy, or an "X" frame style ? You may want to consider header/manifold fitment issues. Has anyone done a swap on that generation of car ? . You may want to see how much work it will be to get the engine in place.
Old Nov 29, 2013 | 09:31 PM
Paul Bell's Avatar
X-Frame.
Old Nov 29, 2013 | 09:59 PM
Camaro_85's Avatar
Just putting this out there, cost seems to be a big difference between the two atleast in my area motor and parts wise.
Old Nov 29, 2013 | 10:08 PM
NnOoSsSs's Avatar
Idk a project like this would have its up and downs for whichever, idk ive always wanted to build a sbc they seem fun to mess around with. One of my buddys did a nice build in a s10 years ago since then ive always wanted to do one
Old Nov 30, 2013 | 10:07 AM
JDMC5's Avatar
here's a few highlights
- six bolt mains. The block extends past crank centerline, also structural oil pan creating a much more ridged design.
- all aluminum
- roller fulcrum rockers
- 15* valve angle at the worst.
- symmetrical intake runners
- better ignition.
- better gasket sealing
Old Nov 30, 2013 | 10:31 AM
wildcamaro's Avatar
No competition Ls hands down..cheaper power, lasts longer, better mileage, more efficient...enough said
Old Nov 30, 2013 | 10:48 AM
Paul Bell's Avatar
It's not an issue of which is the better engine (an LS is obviously the better of the two). It's an issue of what's best for the vehicle and it's owner. It may be difficult enough to go with the LS engine that staying with the SBC might make more sense.
It's up to the OP, his level of expertise, time and funds.
Ultimately, in this case, staying SBC would be less costly and less work.
I don't think the vehicle is being built as a road or track racer and a decent built SBC can still make pretty good power.
Old Nov 30, 2013 | 01:18 PM
dirty_old_chevy's Avatar
If you are just looking for ***** out low end with a stock converter, just go with the sbc.
Old Nov 30, 2013 | 01:39 PM
726.0chevelle's Avatar
13 Second Truck Club
To me it all depends on your budget, mechanical ability, and horsepower goals. Ls more money but easier to make power due to the better designed heads and factory roller cam.
