Nova Camaro PCM mounting?
I would prefer to have it out of sight.
Initially i was going to remove the glovebox and mount it there. I keep thinking if i ever go to put in an underdash ac system it would probably be in the way. (not sure it will ever get AC realistically).
The other spot i was considering was under the drivers side fender, behind the wheel well, i do not think there is room on the passenger side with the blower motor there.
Any input is appreciated.
I made a sheet metal mount to attach to the plastic OEM F-Body PCM Mount. It attaches to the area of the dash under the Ash Tray and then attaches to a upper loaction inside the dash. There is a lip and provision for the upper / middle Vents (mine doesn't use it and the dash is covering it up). I know my 69 Camaro also had the same opening for the AC/Vent.
If you take the top Dash off, you will can see it. . I only had to modify the Glove box corner about 3/4".
It is documented in my Build Thread (follow the link in my sig). But here are some pictures.
BC
I used rivetnuts and vibration isolation studs
I pulled the left side inner fenderwell tonight. I think its a perfect spot for it. I made a cardboard template for the PCM. Hopefully have it mounted this weekend and start on re-doing my GTO wiring harness.
