Motor dies when making a quick stop
I'm running a th400 with an internal VSS btw. The pcm has been throwing two trans related codes P1810 and P1860. Which kind of pisses me off since my tuner knew I was running a TH400 and I assumed they would have tuned the pcm for a manual. Btw the tune is a mail order from Texas Speed to get the car rolling.
Someone earlier asked if I was running drive by wire or cable. I'm running drive by cable.
Also I wouldn't think you should need the brake switch hooked up without a lock up TC or electronic trans, but couldn't hurt I guess. The ACDelco part number is D850a, but you can cross that number with other brands.
After getting a pulse generator from Dakota Digital, it no longer hesitates upon braking.
Most people say its not the problem and other do. I'm just saying that $40 part is what fixed my problem.
Just my .02 cents!
Pat
But on a street driven car... It might not hurt too much... But it most likely adds more to the drivability functions. Just an opinion...
BC
I may FINALLY get a chance to do the brake switch this weekend and if I do that I will purposefully let the tank go below 1/2 and see what happens. But that pump whines like a **** when braking and the tank is low. I'm also going to reroute my fuel return line to the top of my tank (currently going into the sump where the fuel exits as well). There is probably too much turbulence there affecting pumping.
Once I get the Brake switch hooked up I'll report back any changes. Thanks again to everyone who contributed to this thread!!!!
