Converting DBW to DBC
Old Dec 15, 2013 | 09:30 AM
ion05's Avatar
Default Converting DBW to DBC
Currently have a 2002 vortec 5.3 motor that is DBW talked to Jon from PSI about a harness and tolds me I could save alot of money converting to DBC. My question is what would i have to upgrade to go from DBW to DBC?
Old Dec 15, 2013 | 05:41 PM
sbf's Avatar
sbf
A cable driven throttle body and a ECM that's cable driven acceptable
Old Dec 16, 2013 | 09:33 AM
ion05's Avatar
I ordered harness from PSI and a dbc throttle body should be good to go
Old Dec 16, 2013 | 09:49 AM
BadWolf's Avatar
do you need a different gas pedal?
Old Dec 16, 2013 | 10:16 AM
garys 68's Avatar
You'll need the ecu tuned for cable TB and add an IAC.
The 02 411 ecu can be easily tuned for that.
Old Dec 16, 2013 | 12:17 PM
ion05's Avatar
no you can keep the stock mustang gas pedal for the cable
Old Dec 16, 2013 | 04:20 PM
BigEd_72455's Avatar
If I can ask, what did those wind up running you?
Old Dec 16, 2013 | 10:13 PM
ion05's Avatar
harness, PCM tuned,throttle body for dbc, and the cable itself came to $1200 shipped to my door from PSI
