ignition and starter on fox body
Old Dec 17, 2013 | 10:17 AM
ion05's Avatar
Default ignition and starter on fox body
Have a 91 foxbody mustang and was wondering what starter could i use either the stock mustang starter or a chevy taho starter? and second question how did you all go about the electrical wiring and starter to alternator wiring?
Thanks in advance
Old Dec 17, 2013 | 11:01 AM
soundengineer's Avatar
what motor is going in the car...
if its a GM Motor, you need a GM Starter for that motor. its all about how it bolts up and how the teeth align with the flywheel
starter and alternator are like any car...
alternator to the battery
starter to the battery thru a fuse and solenoid activation goes thru the Column wiring.
Old Dec 17, 2013 | 01:02 PM
ion05's Avatar
Its a LM7 5.3 off a Chevy taho
Can you elaborate?im a bit confused
Old Dec 17, 2013 | 06:41 PM
you need a GM starter..
if you use a flexplate/flywheel from a Chevy Tahoe, you should get a starter for one as well
you cannot use a mustang starter on your GM engine...it wont bolt up, and it likely wouldnt line up...
what else are you confused about?
Old Dec 17, 2013 | 07:39 PM
krochus's Avatar
If you even have to ask if you can use a ford starter on a Chevrolet motor you're going to need help with a great deal more than just the starter wires.
Now believe it or not I did get to use the mustang starter wires and solenoid on my suburban starter
Old Dec 18, 2013 | 08:08 PM
ion05's Avatar
I am a nub at electrical hence why I ask questions so probably just going to get the GM starter and alternator and get it done at a shop.
Old Dec 19, 2013 | 08:19 AM
1bad03snake's Avatar
That's probably a good idea. Good luck
Old Jan 28, 2014 | 01:48 PM
ion05's Avatar
anyone have pictures of their ignition to starter wire set up? or what wires where spliced from the foxbody to the lsx starter. Thanks in advance
Old Jan 28, 2014 | 02:34 PM
this is What mine Does
Old Jan 29, 2014 | 02:23 AM
ion05's Avatar
Have a Psi wiring harness. So from I've been reading I splice into the mustang ignition wire either a brown or yellow then run it to the chevy starter?
