VHX gauges and E38 ECM Speedometer output
Old Dec 19, 2013 | 09:50 AM
Hart_Rod's Avatar
Default VHX gauges and E38 ECM Speedometer output
Has anyone when been able to get their VHX speedo to work with a E38 ECM? I have a Speartech harness that pulls the speedo output from X1J1 pin 57. When I wire that directly to the VHX box (speed sender), I dont get any pulses. However when I have my HPTuners scanner connected via the OBDII port, the speed output displays perfectly on the scanner. Any suggestions? Thanks,
Rob
EDIT: I forgot to mention this is for a 6L80 and you can't use the Dakota Digital signal generator.
Old Dec 19, 2013 | 11:47 AM
1989GTA's Avatar
I believe HP gets the signal off the GMLAN wires. There is communication between the transmission TCM and the E38 and the VSS signal is part of it. Some have tapped into that wire with success. It did not work for me. Without looking it up I think pin 57 may be an input from wheel sensors.
Old Dec 20, 2013 | 09:42 AM
Hart_Rod's Avatar
Thanks GTA. I got that info off of HPTuners website:
http://www.hptuners.com/forum/showth...one-of-the-OSS
I'm working with Dakota Digital trying to figure it out. I'm sure it's something simple, either in the TUNE or something on the control box. I know I shouldn't worry about this, but it makes doing the tune a lot easier when you can see how fast you are going from the gauges and not having to look at the laptop.....
Old Dec 20, 2013 | 01:06 PM
1989GTA's Avatar
Thanks for the link. I will look into my setup.
Old Dec 20, 2013 | 04:11 PM
1989GTA's Avatar
Update: I looked up my notes and I did add a yellow/black wire to pin 57 of J1. I also have checked the "serial" output on HP Tuners in the speedometer section. Car is still at the paint shop so I can't physically look at it. I will check it out when I get the car back. Seeing as I have to 2011 Corvette tune this might work.
Old Dec 20, 2013 | 08:12 PM
Hart_Rod's Avatar
Update: I looked up my notes and I did add a yellow/black wire to pin 57 of J1. I also have checked the "serial" output on HP Tuners for the speedometer section. Car is still at the paint shop so I can't physically look at it. I will check it out when I get the car back. Seeing as I have to 2011 Corvette tune this might work.
89GTA would you mind sending me a copy of your tune?
Rob
Old Dec 20, 2013 | 08:41 PM
1989GTA's Avatar
I will see what I can do. It will be a first for me.
Old Dec 20, 2013 | 08:53 PM
futureuser's Avatar
My e38 works fine with dakota vhx. As long as you can get it to pulse, the gauges will calibrate.
Old Dec 20, 2013 | 09:00 PM
Hart_Rod's Avatar
How did you set your tune up to make it pulse?
EDIT: Just ready your build. You have a 4L60E, I have a 6L80, totally different beast...
Old Dec 23, 2013 | 12:05 PM
Hart_Rod's Avatar
GTA - thanks for the file. I set mine up like yours, but still a no go. I did verify that there was nothing wrong with the DD control box by connecting the sender that they send with the kit and using my electric drill to turn it. It worked as advertised, . So that leaves the wire or the tune. I did a continuity check on the wire and double checked the pin location and all checked good. Now I just need to find an oscilloscope and see if the computer is putting out the correct signal on the wire.....
Old Jan 22, 2014 | 10:25 PM
1989GTA's Avatar
I wonder if a 1K pullup resistor from 12vdc would be needed for the speedometer signal? I know one is generally needed for the tachometer.
Old Jan 23, 2014 | 06:25 PM
Hart_Rod's Avatar
I can try that. Do I just wire it inline with the input wire to the speedo?
Old Jan 23, 2014 | 07:32 PM
Rocketrod's Avatar
I used Autometer gauges my harness was originally wired to use a signal out of the TCM, but it wouldn't work. I had to tap directly into the VSS signal coming directly out of the trans for it to work. I would have to look at my notes to see if it was the hi or low signal, but I try them both, separately, and see if it helps. I also notice the PPM setting in HP Tuners had no bearing on how the speedo functioned.
Old Jan 23, 2014 | 11:10 PM
1989GTA's Avatar
The 1K resistor would "T" off the wire and the other end of the resistor would go to a 12v source. Hartrod, if you do get it to work be sure to post what you did and the settings in the ECM.
Rocketrod: I tried that with my Speedhut speedometer and that did not work. I tapped off the high signal. Apparently it works with the Autometer gauges.
I do have a solution as I bought a Speedhut speedometer that works with the GMLAN wires. However I want to play with this and see if I can get it to work on the standard gauge. I am using the X1-57 pin.
Old Feb 9, 2014 | 06:56 PM
Hart_Rod's Avatar
Ok guys, I finally got the solution for the problem.
Originally Posted by Chris@HPTuners
please post up your tune so I can take a look or email me chris at hptuners.com
Hi Rob,
Please download the latest 2.24.469 or later.
I have added a new parameter to the speedo section called “Speed Output Type”, try setting this to “VehSerial”.
This parameter is used by the ECM hardware driver to initialize the output correctly.
Please let me know if it works.
Chris…
Chris - I downloaded the new version and made the changes - you da man!!! The speedo now works correctly!!! Thanks again,
Rob
Old Feb 9, 2014 | 08:44 PM
1989GTA's Avatar
Rob
Just as I tore my dash appart to put in the Speedhut speedometer that uses the GMLAN signals. I can still put the old one back in I guess as it is still apart. I would rather use the signal out of the ECM. That way I can use HPTuners and without messing up the speedometer. What do to, what to do?
Old Feb 9, 2014 | 09:01 PM
Hart_Rod's Avatar
Make sure you download the latest version of HPTuners so you can make the change that is required. Let me know if you need any help.
Old Feb 9, 2014 | 09:13 PM
1989GTA's Avatar
Thanks. Downloading right now. I assume the port on the ECM is J1-57? I will go ahead and put the old speedometer back in and see what happens.
Old Feb 9, 2014 | 09:18 PM
1989GTA's Avatar
Ok, just down loaded the latest version. Went to speedometer setup and it has for "output source" the following :
1. Disabled
2. Rep TOS
3. Serial.
I assume number 3 (serial) is the one to use with this latest version of HPTuners? Thank you for getting to the bottom of this problem.
Edit: By the way the latest version is now 2.24.476.
Old Feb 9, 2014 | 09:42 PM
Hart_Rod's Avatar
Here's how I have mine setup:
EDIT: I downloaded it yesterday and it says 2.24.469... strange....guess I just need to update mine about every 2 weeks...
